Speaker Wire Hookup to Receiver Question
jgrog
jgrog Posts: 8
I prewired my basement walls/ceiling for in-wall Polk Speakers; however, I am not sure whether to pull wired directly to my receiver or use a panel with cable to receiver. I suspect less loss/issues with direct method.
Does anyone have an opinion regarding best wiring method?
Post edited by jgrog on
  • apphd
    apphd Posts: 1,514
    edited March 2009
    jgrog, welcome to CP. I've always felt the fewer connections the better as you stated. But in this case I would go with a wall panel and banana plugs on both ends. If you have the correct gauge wire for the runs I do not believe there will be enough signal loss to worry about.
    This is just my opinion and preference for a cleaner look and ease of connecting/disconnecting for troubleshooting, cleaning etc.
  • ben62670
    ben62670 Posts: 15,969
    edited March 2009
    I like direct. I would just make sure that the box in the wall accepts the proper plate for the future. If/when you sell the house it looks better to the prospective buyer if it is neat.
    Ben
    Ben
  • jgrog
    jgrog Posts: 8
    edited March 2009
    Thank you for the feedback.
