One Slammin Sub
Systems
Systems Posts: 14,873
edited July 2003 in Car Subwoofer Talk
I decided to go with one 10 inch Kicker sl7 dual 2 ohm sub. It is hooked to a US acoustics pushing 450 by one and it hits harder than the momo 12 that it replaced. I couldn't believe it. Polk components still rule though...Those square Kickers are NASTY hitting subs...still can't believe it is only one 10!
Testing
Testing
Testing
  • sntnsupermen131
    sntnsupermen131 Posts: 1,831
    edited July 2003
    yeah theyre very loud and will kick a momo's **** anyday...mainly b/c theyre square and have more surface area and theyre more efficient too
    but the momos sound a lot better than the kickers do...momos-SQ
    kickers-SPL
    depends on what ur going for
    im not sure but isnt 450 a little weak for that sub?
    not trying to offend anyone like i did in a previous post...but arent they rated a lot higher than 450?
    -Cody
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited July 2003
    650 last time i checked cody -- 750 for the 12...
    and usually they put MORE than that on them -- ie. almost a grand on the 12"
    the L7 is best in a ported box -- and u're right, they're dirty as hell... loud as hell but dirty as hell.
    two completely difft purpose speakers... and thus an unfair comparison.
    *points to self* <---- could care less about offending ppl.. :)
    The Artist formerly known as PoweredByDodge
  • Systems
    edited July 2003
    yeah the momo sounded better..
    Testing
    Testing
    Testing
