One Slammin Sub
Systems
I decided to go with one 10 inch Kicker sl7 dual 2 ohm sub. It is hooked to a US acoustics pushing 450 by one and it hits harder than the momo 12 that it replaced. I couldn't believe it. Polk components still rule though...Those square Kickers are NASTY hitting subs...still can't believe it is only one 10!
Testing
Testing
Testing
Testing
Testing
yeah theyre very loud and will kick a momo's **** anyday...mainly b/c theyre square and have more surface area and theyre more efficient too
but the momos sound a lot better than the kickers do...momos-SQ
kickers-SPL
depends on what ur going for
im not sure but isnt 450 a little weak for that sub?
not trying to offend anyone like i did in a previous post...but arent they rated a lot higher than 450?
-Cody -
650 last time i checked cody -- 750 for the 12...
and usually they put MORE than that on them -- ie. almost a grand on the 12"
the L7 is best in a ported box -- and u're right, they're dirty as hell... loud as hell but dirty as hell.
two completely difft purpose speakers... and thus an unfair comparison.
*points to self* <---- could care less about offending ppl..
The Artist formerly known as PoweredByDodge -
