what tweeter is this RDO 198 or 194?
zarrdoss
zarrdoss Posts: 2,562
edited February 2009 in Vintage Speakers
I got these for replacements and unless they changed the way they look these look to me to be 194? not 198's like I ordered.
http://s651.photobucket.com/albums/uu237/zarrdoss/?action=view&current=IMG_0871.jpg
    heiney9 Posts: 25,666
    No way to tell w/o looking at the terminals on the back of the tweeter. I can't remember which is which but one of the models has both spades (clip on) the same size and one model has one larger than the other (width).
    As far as I know that's the only way to tell as there is no printing on the tweeter and from the front they both look identical.
    F1nut Posts: 52,365
    You can't tell from the front as they look exactly the same. The only way to tell is the connectors on the back. The RD0198-1 has one large spade and one small spade.
    If the paperwork from Polk states they are 198's chances are they are 198's.
  • Ron Temple
    Ron Temple Posts: 3,212
    Should be a lable on the magnet saying SL2000(94) or 3000(98). Another way to tell is the 94 has the same size connection posts. The 98 has one wide one and one thin one. They look alike from the front.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • zarrdoss
    one large one small we have a winner. All the pics I have seen the tweets have a like weather stripping gasket around the dome on the front like the sl 2500 and sl 3000, Thank you! you guys are the best!
  • zingo
    zingo Posts: 11,258
    Yes they are. :D
  • hearingimpared
    hearingimpared Posts: 21,136
    What are you putting them in?
    zarrdoss wrote: »
    Correct the sl2500 and sl3000 have the "foam" ring around the dome. The 'new' RD0's don't have that.
  • zarrdoss
    they are going in some sda srs 2.3 tl that I just refinnished
  • hearingimpared
    zarrdoss wrote: »
    Nice, you're going to love them. The first 30 hours or so they sound a little hollow but once they start to break-in, oh baby!
