Upgrading speakers/finishing off system
mccarts747
mccarts747 Posts: 48
edited June 2003 in Speakers
new to the board....
I am in the process of finishing off my Home theatre system. I now have Onkyo SR600 6.1 Polk CS175 center, R40's for main l/R, Cambridge Soundworks Sub, and some old Bose 101 for Surrounds. Prices are falling at Circuit City/Crutchfield on the RTi series. I am contimplating the RTi 38, the CSi30, and the FX30's. I can not get them all at once so, I was looking for any advice on what set up might work best for the Front mains. Keep the R40's and wait till I can afford another set of towers replace them with the RTi38's, or just keep the rti38's as speakers for a seperate room.
any ideas/advice would be appreciated
Shawn
___________
Onkyo TX-NR609 (receiver)
Sony Blue ray Player
Sony 46" LCD TV
Comcast HDTV X1
VM10 (Center)
VM10 (Front Mains)
FXi30 (surrounds)
Cambridge Soundworks Cube8 (sub)
Post edited by mccarts747 on
  • dorokusai
    dorokusai Posts: 25,638
    edited June 2003
    I have that setup, and just so you know, it works great :)
    Would you be into looking for a set of RTi70's at CC? Then you could upgrade your mains, still a tower, and move the R40's into surround duty.
    Then I would probably get the CSi30/40 and then your front stage is complete. FXi30's last.
    This just happens to be what I did, just with RTi38's as my mains. You will get a little more bass from the RTi70's then you will with RTi38's as mains. The sub is probably the last and largest investment I would suggest. Do a search on the forum at that time, there is alot of information for sub purchase, no need to expound upon that here.
