Where can you get this???
amulford
amulford Posts: 5,020
edited June 2003 in Flea Market
I was just perusing and I found this...
http://www.hifichoice.co.uk/review_print.asp?ID=85
I bet this would sound pretty good though.
does anyone know anything?:confused:
Is it still available?:confused:
Post edited by amulford on
    VR3 Posts: 29,697
    edited June 2003
    Go to the Home Audio home page, below the Navigation section, you will find a Vintage Section, and Recent Section. Click recent, you will find all the speakers you want to find there.
  • brettw22
    brettw22 Posts: 7,623
    edited June 2003
    As a set it's not available. You can search for the pieces individually, which as listed on that page are:
    The RT5000 comprises three sets of speakers - a pair of RT3000's, a CS1000p, and a pair of f/x1000's
    . The center and surrounds tend to surface more often than the RT3000's, but they still are around every once in a while. Also check out Audiogon for these items since they tend to have things a little more frequently than Ebay. Good Luck......
    EDIT:
    Here's what's on Audiogon right now:
    RT3000p's
    I didn't see anything on Ebay that would fit what you're lookin for unless you stepped down on the surrounds and went with either the f/x500i or the fxi50.......
