Where can you get this???
amulford
I was just perusing and I found this...
http://www.hifichoice.co.uk/review_print.asp?ID=85
I bet this would sound pretty good though.
does anyone know anything?
Is it still available?
Post edited by amulford on
Go to the Home Audio home page, below the Navigation section, you will find a Vintage Section, and Recent Section. Click recent, you will find all the speakers you want to find there.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
As a set it's not available. You can search for the pieces individually, which as listed on that page are:
. The center and surrounds tend to surface more often than the RT3000's, but they still are around every once in a while. Also check out Audiogon for these items since they tend to have things a little more frequently than Ebay. Good Luck......The RT5000 comprises three sets of speakers - a pair of RT3000's, a CS1000p, and a pair of f/x1000's
EDIT:
Here's what's on Audiogon right now:
RT3000p's
I didn't see anything on Ebay that would fit what you're lookin for unless you stepped down on the surrounds and went with either the f/x500i or the fxi50.......
