Can i Bi-Wire my set up?
Pauly
Now i have done a little research on bi-wireing but am still confused? Seeing that "bi" is 2 i got that you need 2 sets of wire (or the monster bi-wire kit(s) Is there extra plugs on the amp or speakers to acheive this? Or do you just run 2 seperate lines for this? I have look at the back of my setup and didnt see this but then again maybe i didnt spend enough. Please elaborate. Thanks
___________________
Onkyo TX-SR 500
Fronts RS 50
Center CSi30
Rears Kenwood Somethings (FXi30's on layaway
PSW350 stacked with PSW404 just traded in the 202 today
___________________
Love is neat, love is sweet, but love is something you cannot eat!
___________________
Onkyo TX-SR 500
Fronts RS 50
Center CSi30
___________________
Life without music would♭
Post edited by Pauly on
tried to upload pic of setup but file is too big even zipped. any sugg?Life without music would♭
To bi-wire your mains you will need four equal lengths of wire; two for each side (right and left speaker).
Now take two equal lengths of wire, check for the polarity on the two wires and twist the two positives together and twist the two negatives together. Then use a crimp on banana plug or spade to secure the twist. This end goes on your left or right output from your receiver.
Remove the straps on the back of your speakers on the posts and run the other end of the wires to your speakers. Positive to Positive .. negative to negative and so on.
Repeat for the other channel and enjoy.
Yes, they do make bi-wire speaker cable if you don't want to make it yourself out of individual runs.
Paul
And last but not least .. welcome to the forum.. -
Food 911, great show.
Your speaks are not bi-wireable, fagettaboutit.
Cheers,
Non bi-wireable...well I guess forgetaboutit is correct!!
Oh well...
P. -
Spasticpitbull, If I'm not mistaken I don't think you can bi-wire the R50's. Where the speaker terminals are on the back of the speaker, you should have 5 way binding post, which means you should have 2 positive feeds and 2 negative feeds. If I'm not mistaken I think the 50's only have single set of binding post. I'm pretty sure you can't bi-wire your fronts but if someone here can tell me something different I would really care to hear.Money Talks, Mine says Goodbye Rob!!!!
Looks like i need to trade em in for the RTi70's i just looked and they have the capibility. Anyone give good reviews on these?Life without music would♭
