Double PSW 150 question
Vette C6.r
Vette C6.r Posts: 1,560
Hello all. I have two PSW150's. They are displayed next to each other.
My question is what shouel the phase be on both. I have one reversed and the other not. My understanding is that the soundwaves would work as one pushing and one pulling.
What about the crossovers. I have one on the highest freq. and the other on the lower freq. is this the best setup??
I have a Pioneer Elite rec. I believe the new 94. Sweet receiver.
Thanks for the help.
TK
Post edited by Vette C6.r on
  • TheMARPATNinja7
    TheMARPATNinja7 Posts: 150
    edited February 2009
    I don't know a ton about phase but what I do know is, you shouldn't judge that by anything technical, you should listen to it in all different phase selections and decide what is best for yourself and your specific set up. If it were up to me I would have each sub crossed over at the same frequency. If somebody knows something that I don't, feel free to correct me on this.
  • Mike21
    Mike21 Posts: 252
    Hi Tk
    I would seperate the subs - one in each corner of the room and set the FR cutoff at 80Hz. Then set the phase as described in the previous post. If that doesn't sound better, put the 2 subs back side by side.
    Don't be shy about experimenting.
    Mike21
    ____________________________________________
    Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
    PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    Another option is suggested by THX's website to put them in the middle of opposing walls (see attached link below) While I agree it is best to experiment and see what works best for your setup, this is just another option for you to explore.
    http://www.thx.com/home/setup/speakers/sub.html
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Vette C6.r
    Wow. Thanks for the response guys. I never thought of stacking one on top of the other. That would save some room.
    On movies the bass seems WAY too much but on musical Blurays it is always insufficent and I have tried everything that I know in my febale brain.
    I will try the XO on the reciever. I have a new Pioneer Elite receiver. Not sure the model of it while I'm at work.
    Thanks for all the info. I appreciate the help. New to this- it's good to know that others share our affliction.
    Thanks again
    Vette C6.r
