New to home theater
Hi,
I recently bought a new TV and Blu-Ray player. I would like to compliment the pair with a surround sound system. A few people recommend Bose to me but for the that money I feel I can get a much better system through POLK. I have very little experience with home theater and hoping a few of you can point me into the right direction.
My TV is mounted on the wall and would like wall speakers in the front and for the back. My den is approximately 16x16. My budget is approximately 3k for the speakers.
Thanks,
Anthony
Thanks,
Anthony
Post edited by acmf74 on
You are a wise man... If you want to catch up on the latest Bose banter on club polk - here's the link:
http://www.polkaudio.com/forums/showthread.php?t=77953
My experience is mostly with RT, RTi, and RTi A speakers, which may be a little pricey for your starter system, and may be a little large for a den / family room application like you're talking about.
Some of the other folks here would probably be better equipped to tell you about polk's smaller sub/sat systems...
Anyway, good luck and welcome to club polk! -
acm, when you say "wall speakers" are you talking wall mounted, or "in wall"?
I have heard some good comments on the Polk inwalls, but know nothing about them myself. As far as wall mountable the Vm series bookshelfs are and have a nice looking 5.1 VM20 system, but I have never heard them. The TSi100's are easily mountable as well, but I would prefer the 200s for fronts, if I was to go that route. I think that there are manufactures of wall mounts that should be able to handle most bookshelf speakers but that would take $$ from your budget that should stay on the speakers. Mantis, a CP regular is a custom installer, not sure if he installs Polks but I'm sure he could give you some good advice on in walls in general.
Almost forgot, welcome to CP -
What receiver/prepro will you be using?TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
I'm starting from scratch and will be buying everything new.
I can go either in the wall of mounted... -
Hi ac.
What is your overall budget (speakers, avr receiver, speaker wires, interconnects), or at least your budget for speakers?
Are you planning on a subwoofer?
Mike19____________________________________________
Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors. -
Hi ac.
Mike19
Op states he/she has 3k. I'd go RtiA5s or 7s, CSiA6 center, FXiA1, SVS PB12 Plus sub. If you dont have receiver, I'd pair everything up with Pioneer Elite SC05.
If that exceeds your budget, go Rti10s, CSi5, Fxi3s SVS PB12 Plus sub, this setup can be found all over the place (polk direct, ebay, agon, amazon, frys) for a great price since they are no longer made due to the new RTiA speaker replacing them. That SVS sub will definitely bring life to the party. Welcome to the forum, whatever route you go, enjoy it.Shoot the jumper.....................BALLIN.............!!!!!
+1 on that suggestion. That's close to what I'm going to be setting up here in another month or so.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Another welcome to the forum. Checkout amazon & the Polk ebay store for deals on older/ refubished items. +1 for the Pioneer SC-05, IF ou can afford it.I refuse to argue with idiots, because people can't tell the DIFFERENCE!
Sherardp.CCurt, while I like those speaker selections;)unless I misunderstood the OP he is looking for in wall or wall mounted front and rears.
