The RTi12s Are Up and Running, But...
Mike LoManaco
Mike LoManaco Posts: 974
edited April 2010 in Speakers
...they don't seem to want to play nice with my PSW350 crossed over at 80Hz...
Is there another recommended crossover point for the 12's that would allow them to provide some of the bass they're capable of, yet not overpower or rob from the PSW350?
Post edited by Mike LoManaco on
«13
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2010
  • SolidSqual
    SolidSqual Posts: 5,218
    edited April 2010
    Set the 12s to large and the sub to kick in at 80Hz. Dial the sub volume and crossover up or down per your listening preference.
  • Menasor
    Menasor Posts: 283
    edited April 2010
    I would recommend 60hz
    Fronts: Energy RC-70
    Center: Energy RC-LCR
    Surrounds: Energy Veritas 1.0CM
    Subwoofer: SVS PC12-NSD
    Receiver: Onkyo TX-SR705
    Amplifier: Denon POA-2200 w/ Ben's ICs
    Pics of my setup (click me)
  • Mike LoManaco
    edited April 2010
    leroyjr1 wrote: »
    Try fullrange
    Leroy,
    I would rather not run these full-range; I'm already using a receiver that's not really ideally suited for speakers like these -- I need to take all the strain off the receiver's amp as possible...
  • Mike LoManaco
    edited April 2010
    SolidSqual wrote: »
    In the AVR?
    At the back of the sub?
  • Mike LoManaco
    edited April 2010
    Menasor wrote: »
    Thanks Menasor,
    Set the mains in the AVR to roll of at 60Hz? Would this allow more bass to come from the RTi12's?
    I just don't want to drown out the PSW350, either...
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2010
    Have you run audyssey?
    I'm assuming not, because a while back you said you "preferred manual adjustments".
    Run audyssey, then report back.
    How exactly are they "not playing nice"? Is one overpowering the other? Not blending well? We need more info.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • leroyjr1
    edited April 2010
    Thanks Menasor,
    If the 12's overpower the sub then it might be time to upgrade it or recalibrate your system. The most important thing you can do is play around with placement and the setting to see what sounds best to you. Every room and peoples taste will be different.
  • Mike LoManaco
    edited April 2010
    Hey 'Curt,
    Thanks for the input. No, as you suspected, I haven't run Audyssey.
    It just seems as though the PSW350 isn't as "tactile" in slam as it once was, and that's with raising the sub's actual volume knob and level inside the AVR; I was assuming this was because perhaps the 12's are "robbing" it of some LFE, but it's difficult to explain...
    I suppose I am just asking for the optimum setup for the 12's to be run not as full range along with the PSW350.
    Here are my settings, for reference:
    On the rear of the sub, PHASE set to "0" (although I could swear 180 gave more slam...) and LOW PASS set all the way up to 160Hz...
    Is this correct?
    Further, I was never able to get any concrete answers from my installers I worked with on this setup nor anyone online as far as if I had the actual 12's connected physically correct -- that is, I'm not running them bi-amped, just normal into the Onkyo 605, so I connected the speaker cables to the TOP set of terminals on each RTi12, leaving the gold-plated "belt" between the terminals on...is this correct?
  • Mike LoManaco
    edited April 2010
    leroyjr1 wrote: »
    I understand that at a certain point it's a matter of taste, but there are some concrete facts that need to be looked into here; firstly, I have been told that the RTi12's can actually outboom a sub like my PSW350 and may put out more bass than the sub is capable of -- but at this point, I don't have the resources to do any more upgrades, so I must make the 12's work with the PSW350 as best they can.
    So, I need to find a way for the 12's to co-exist with the 350 and have them play together seamlessly; I want the 350 to put out all the low bass, but get some of the bass/midbass the RTi12's are capable of at the same time...
    I'm looking for crossover suggestions based on these criteria...
  • comfortablycurt
    edited April 2010
    It makes no difference which pair of inputs on the 12's are connected. That's what the jumpers for. You're fine with them in the top terminals.
    It may very well be that you need to set the sub for 180 in your situation. Try it again, and see if it sounds better.
    Try audyssey, and try doing some listening with the subs phase switch in either position.
    Yes, the subs lowpass should be turned all the way up.
    You have the sub connected over LFE from your Onkyo, correct?
    What is the subs crossover set at? 80 I'm assuming? Set it to 100 or 120hz and report back.
    We'll get you up and running.:)
    Toolfan66 Posts: 18,074
    edited April 2010
    Mike is there anybody here that lives close to you to help you out? it just seems like you have struggled with your system for sometime now, and if someone can come over to help you out it might help you get your learn on. sometimes if someone is there to help guide you it's easier to pick up.
  • Mike LoManaco
    edited April 2010
    Thank you. This ensures they're just getting normal power loads from the 605's main channels, correct?
    I'll run more tests and get back...
    Even though "all the way up" on the 350 is 160Hz? This isn't "too high"? I suppose not, because I am using the AVR for crossover control...
    Yes -- one subwoofer RCA cable is going fom the 605's LFE OUT to the PSW350's UNFILTERED LFE IN. That's it.
    Do you mean for the main channel rolloff inside the AVR? Yes, that's at 80Hz for ALL channels.
    Thank you...:D
  • Conradicles
    Conradicles Posts: 6,343
    edited April 2010
    Set the mains to large, becasue they are very large, and run the room eq. Then tailor the sub to your liking. How you like it.:)
  • comfortablycurt
    edited April 2010
    Yes, that's just for bi-wiring purposes. You'd need to remove the jumpers between the posts if you wanted to bi-wire. I wouldn't worry about that too much though personally.
    Yes. The crossover control on the sub itself should be completely bypassed by simply connecting something to the LFE input, but it's best to turn it up all the way just to avoid the slim possibility of double filtering the signal. It's just to get it completely out of the signal path. Your AVR will be controlling the crossover point.
    Yes, that's what I was referring to. I'd try setting the crossover for the sub(in the AVR) to 120hz. That's going to give the sub a lot more slam, since it will be carrying a wider range of low frequencies.
    A movies soundtrack contains LFE content all the way up to 120hz anyway, and is the best point for it to be set at. It also makes for a much more natural rolloff between the sub and the mains in my experience.
    All of that being said, there is no one "best" setting. You're going to need to play around, and try different settings in order to see what sounds best to YOUR ears.
  • Menasor
    Menasor Posts: 283
    edited April 2010
    Setting the crossover to 60hz would give your RTi12's some more room to flex their muscles, while still giving your sub a good workout with all content 60hz and below. I set my RC-70's to 60hz crossover because they are full range towers like your RTi12's. Works great for me.
    Also, definitely run Audyssey
  • Mike LoManaco
    edited April 2010
    Sometimes it doesn't matter how physically "large" a speaker is; it has to do with the strain a setting like Full Range puts on a receiver -- in my case, I am running a receiver that shouldn't even be hooked up to power pig speakers like the RTi12's, so I need to keep the strain off this receiver as much as possible. Running these as Full Range I don't think is the right move here, unless others chime in with their thoughts about it...
  • Menasor
    Menasor Posts: 283
    edited April 2010
    If you think full range is too much, and 80hz is too little, then you should start lowering the crossover in increments of 10 until you find the balance you like (starting with 70hz)
  • Mike LoManaco
    edited April 2010
    Thank you.
    So, 160Hz is okay for the maximum level of the knob?
    I don't have a crossover setting for the sub itself in the AVR -- do you mean the "LOW PASS FILTER of LFE" setting on the Onkyos? Oh, if so, YES, this is set to 120Hz...;)
    Indeed...the LPF of LFE is at 120Hz...
  • Mike LoManaco
    edited April 2010
    Menasor wrote: »
    Thank you, Menasor...I will try 60Hz, because your explanation makes a great deal of sense to me and is what I was trying to get at...:)
  • Conradicles
    edited April 2010
    Yeah for Menasor!!!
  • Mike LoManaco
    edited April 2010
    Yeah for Menasor!!!
    :confused:
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2010
    I think you need to run the Audessey in order to get the most out of your setup. From there you should be able to fine tune making manual adjustments. Those 12s are beast, so in order to get the absolute very best out of your speakers add an external power amp. If you refuse to run audessey then don't expect excellent performance. These adjustments are setup to make room corrections, etc. If you don't take advantage of it, then you should expect some flaws in your SQ.
  • Mike LoManaco
    edited April 2010
    Sherardp wrote: »
    Sher,
    I realize the 12's are beasts, as I have been trying to explain in this thread regarding the fact that I need my AVR to have the least amount of strain on it to power these things...I simply CANNOT, however, right now, add an external power amp for them, so I need to work with what I have...
    Your assesments and feelings on Audyssey are a bit skewed IMO however; I have heard dozens upon dozens of horror stories regarding people getting ridiculously "off" readings from running it, and every time I have run it on my 605, the results were wildly different. I simply just trust my judgements on certain readings Audyssey collects -- the crossover points is a great example. This system pegged my R20 bookshelves as "large" with really poor levels in my last setup, and I'd rather just adjust manually. I don't think by skipping this step it's going to "harm" the connection of my 12's to the 605 in any way -- that's also why I am asking everyone here with the knowledge of these speakers for better physical overriding settings that may work for this combination (RTi12's and PSW350).
    edited April 2010
    I think your overthinking it Mike.. Run the Audyssey and make the adjustments to your liking.. I also think the fronts should be set to small and let the sub take care of most of the lower end at 80hz if your worried about the 12's working your AVR to hard.
  • Conradicles
    edited April 2010
    Yeah for Larry!!!
  • Mike LoManaco
    edited April 2010
    Yeah for Larry!!!
    Dude, not for nothing, but what are you doing?
  • Mike LoManaco
    edited April 2010
    That's what I have been saying about the setup, Tool -- with my particular low-powered AVR, I don't think the RTi12's should be set to "Full Range" in any circumstance; but now the question becomes whether I roll them off at 80Hz or 60...
    In my particular Onkyo, there is no selection for "Large" or "Small" for the crossover setup -- you need to specifiy an exact value for the crossover...so, I need to figure out which rolloff value is better for the 12's with the PSW350, 80 or 60Hz...
  • comfortablycurt
    edited April 2010
    The answer to that is very easy to find out.
    Try both, and decide which sounds better. There's no way that we can tell you which setting is going to sound better in your room, to your ears.
    And yes, 160hz is just fine for the XO control on the sub itself.
    Also, yes, I was referring to the Low Pass filter of the LFE channel.
    edited April 2010
    Looks like you have tried both Mike, you may struggle with this till you can get an amp for your 12's.
    Mike even if you could spring for an Adcom GFA-545 sometime soon you would be a happy camper..
