Sub worked then stopped.
redalert8352
redalert8352 Posts: 2
edited April 2010 in Troubleshooting
Okay i have 2 12 inch Road Crew (Walmart Brand Speakers) subs in a Kicker box. So when i hooked them up they both worked and after a couple mins one of them stopped working. So i took them out to see if i could find out the problem. When i pulled the speaker out i saw that it had a chip inside it.
It has a coil thing and 3 blue things on it. Then it has the things to go to the tweeters and the subs. The other sub works fine and it hooks up the same. Can you help me out with the possible problems?
Thanks in advance. Also i hooked up a different sub into the same one that doesn't work and it didn't work. So i know there isn't a problem with the sub itself.
Post edited by redalert8352 on
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited April 2010
    May have better luck posting a little farther down on our front page in the Car Audio section. If not concealer404 is usually around here as well. Welcome to Club Polk.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • redalert8352
    edited April 2010
    nevermind, i fixed the problem.
  • wutadumsn23
    edited April 2010
    Good to hear you are back up an running again.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
