mm6501 tweeters damaged?
k6ng6r00
k6ng6r00 Posts: 2
edited April 2010 in Troubleshooting
im pushing my mm6501s with an infinity kappa four amp that puts out 125rms per channel. I bought these speakrs because of their high power rating because i didnt want to have to worry about blowing anything. They sounded great at first, but my tweeters have started making weird background noises... they still play and are loud but there is a kind of rattle sound in the background when they are moderately loud... i cant tell if they are blown, or if there is something wrong with the crossovers, or what. the noise seems to be related to when there is bass in the music
Post edited by k6ng6r00 on
  • fbm211
    fbm211 Posts: 1,488
    edited April 2010
    You could have damaged the voice coil.(Or more.)Push in the driver and if it makes a scraching noise its toast.
    What is a mm6501.?
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • k6ng6r00
    k6ng6r00 Posts: 2
    edited April 2010
    the tweeters are 1" diameter there is no way to push it in... mm6501 is the automotive 6.5in mm component set
