ISonic ES2 stopped charging my iPOD!
bennymetal
bennymetal Posts: 4
edited June 2010 in Troubleshooting
I purchased an I-Sonic ES2 in December, everything was fine even after applying the latest firmware. About 2 weeks ago, the ES2 stopped charging my IPOD Touch. Everything else appears to be working fine and the IPOD plays without issue. It just won't charge. I have treid 3 different ipods without any luck. I have searched the net and can not seemt to fond anyone else complaining about this problem. Anyone else have this problem? Any ideas? :(
Post edited by bennymetal on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2010
    Give Polk customer service a call on Monday. You'll get much quicker service calling them, than you will on here.
    Their number is at the top right hand side of this very page.:)
    Did you purchase it new? Is it still under warranty?
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • bennymetal
    bennymetal Posts: 4
    edited April 2010
    Thanks I was planning on doing that and was hoping there was some remote chance that I could avoid having to box this up and send out for repair. Their quality is not what it used to be.... Purchased new & still under warranty but still a hassle. I had major problems with my sub and now this. Granted, Polk took care of the problem but once again I am encountering additional expense post sale. I'll see how this turns out but I think I'm done with Polk.
  • Emlyn
    Emlyn Posts: 4,535
    edited April 2010
    If you haven't already, try unplugging the unit for a few minutes, then plug it back in. May or may not resolve the problem, but it's worth a shot and has solved a few problems I've had with the two units I have. Polk can also send out a firmware update in the mail free of charge.
  • bknauss
    bknauss Posts: 1,441
    edited May 2010
    This is an issue caused buy Apple. They require a special chip be added to docks and accessories to enable charging on the Touch and iPhone. I've seen it referred to as an "Apple Tax" by some people. With the upgraded firmware to the Touch, Apple must have added some code to look for a certain version of said chip or, unfortunately, disable charging. Call up Polk and see if there is an updated IES firmware to fix this issue.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • Eric W
    Eric W Posts: 556
    edited May 2010
    Might be something wrong with the I-Sonic unit, I've seen this only once before when the unit stops charging the iPod. Please give us a call at your convenience :)
    -Eric
    -Polk Audio
  • bennymetal
    bennymetal Posts: 4
    edited May 2010
    I-sonic was sent back to Polk and received by them on 5/7. A replacement unit was sent to me and received today. The IPOD dock charging works great but I get no sound from the speakers. :mad: I called Polk and a new unit is being sent out to me today and they provided me with a UPS label for return of the defective unit. I'll keep you posted...
  • JULRUEDA
    JULRUEDA Posts: 2
    edited June 2010
    Molesto zumbido por la entrada auxiliar del i-sonic desesperante por favor necesito ayuda ya no puedo conectar nada por el axiliar, tengo varios productos polk pero este ha sido un dolor de cabeza gracias no dejen que la marca se deteriore, gracias
    Annoying buzz AUX FOR THE I-Sonic desperate PLEASE I NEED HELP AND I CAN NOT CONNECT THE axillary NOTHING, BUT I HAVE OTHER POLK PRODUCED THIS HAS BEEN A HEADACHE THAT LEAVE NO THANKS MARK deteriorates, THANKS
  • bennymetal
    bennymetal Posts: 4
    edited June 2010
    I received the new Polk unit today and everything is working. One thing for sure is that Polk stands behind their stuff and provides excellent customer service. :)
