How to change between 2ch and 7.1 on reciever.
DillonK
DillonK Posts: 8
edited April 2010 in Troubleshooting
I have a Pioneer VSX 9040txh and I know if I change to stereo it outputs to the 2 fronts and Sub, but what I want to do is be able to switch to nothing but my front two channels for music. I currently have 7.1 speaker setup.
I have tried switching to another memory and turning all the speakers off but my front two channels, but that applies to all my memory settings.
Looking for some advice if anyone could help me out. Thanks in advance.
Post edited by DillonK on
    edited April 2010
    What you need to find is something like the 'pure direct' mode on the AVR...but NOT all AVRs shut off the sub. Without looking at your manual I wouldn't know. But it is easy enough to find in the manual--sometimes all of ''us" have to break that out and read a bit.
    Good Luck..there are a few people here who own a Pioneer VSX-21 which is very similar to your model...maybe someone will chime in?
    cnh
  • holt
    holt Posts: 131
    edited April 2010
    I have the vsx-9130txh-k and it does have a "pure direct" mode which does only utilize just the two front speakers. I'm not sure how similar the 9130 is to the 9040, but I think they're pretty close.
    Pioneer vsx-9130txh-k
    Anthem Pre2L SE
    Marantz cd5003
    Proceed amp 3
    Sherwood Newcastle A-965
    Signal ll IC's
    Polk lsi-15s
    Polk lsic
    PSW505
    Polk Monitor 30 surrounds side and back
    PS3 with modified 500 gig hd
    Samsung ln52a650
  • DillonK
    DillonK Posts: 8
    edited April 2010
    I do have a pure direct mode, I'll have to try that. Thanks for the help. I'll let you know what happens.
  • DillonK
    DillonK Posts: 8
    edited April 2010
    Ah ha! Pure Direct from a stereo source results in nothing but the front two channels. Thanks everyone.
    nooshinjohn Posts: 25,460
    edited April 2010
    Pure Direct also bypasses the tone controls, wich may be a good thing (or bad) based upon your feelings about them.
  • vc69
    vc69 Posts: 2,500
    edited April 2010
    Always a good thing in my not so humble opinion :)
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • DillonK
    DillonK Posts: 8
    edited April 2010
    I usually listen in Direct for movies instead of pure direct because it still takes into account the mic'ing of the room. But for music Pure Direct is the way to go.
