Man I screwed up my LSI's....
avelanchefan
I made a move from Iowa to Arizona about eight months ago. When I had my Lsi's in Iowa they were in a basement setup, fully enclosed not a lot of outside light.
Here in AZ there is a ton of sun of coarse. I was rearranging some stuff, noticed the sides of my LSI's are all faded (Ebony). Man was I freaking pissed.
So I pose this question. What should I do? Should I try to restain them? I have now taken steps for them not to get sun damaged again. But I am unsure on how to fix them.
Post edited by avelanchefan on
If it's real wood, you could always re-stain it, maybe to something more of your liking (unless you liked that shade of ebony). Only thing that's gonna suck is that I think you're gonna have to take apart your speakers entirely to get that wood panel off.........comment comment comment comment. bitchy. -
Would it come back to color if you used a furniture oil on it?
Thanks Brett. I know I would have to take apart the speakers.
MMax....hmmmm may have to try some Murphy's to see if that would work. Any other oil to recommend? -
Also the Ebony on mine was fairly dark. I would say a dark brown to almost black. Now one side of each speaker is a grayish chalk color:mad:
avelanchefan,
There is no oil or wax that will bring back the color and do not use Murphy's Oil Soap. It is a vegetable oil based product ....crap. More than likely they were colored using a NGR dye that has UV protection, but strong sun will fade any dye or stain quickly. The only real solution is to have them stripped, colored and refinished. If you want them to be "black", let me know and I'll tell you how it should be done.Political Correctness'.........defined
President of Club Polk -
Man that just sucks.......
have you caled polk about this??I don't think they warrant sun fade but they might however offer to fix them up abit for a fee.....worth the call.....Thats what I would do,I would call them and see what you can do to get them back to beauty.Dan
Thanks for all the replies fellas.
I have a lot to do this week, but I will be making a decision on what to do this weekend. A call to polk mayb e well worth the time. -
Just an FYI, but I have an old pair of M4s that have faded from age and sun. It doesn't fully restore them, but a good coating of Old English furniture oil makes them look 100% better.
Feel for you ave... had same thing happen to my Grandparents' dining table. Can see where every place mat belongs now...
BTW, WTH are you doing in Iowa and Arizona? Shouldn't you live in Colorado?
Then again, I'm a Browns/ Flyers fan in Texas.. so nevermind...More later,
Tour...
Vox Copuli
LOL Tour......Born and raised in Denver....then got married....now I am a nomad.
