DVD question.
setzer808
setzer808 Posts: 173
edited May 2003 in Electronics
Hey guys,
I just got a new TV (36" RCA (great openbox deal on it) ) and was wondering if I'd benefit from upgrading my DVD player to one with Progressive Scan. The RCA has a 3-Line Comb filter, but is not HD. Will progressive scan ONLY help on an HD set, or is that a myth. Just curious, thanks.
Shaun
Polk CS245i Center
Polk RT55i Mains
Polk RT25i Rears
Polk PSW-350 Sub -in storage.
Yamaha RX-V681 A/V Reciever
Sony SCD-CE595 SACD Player
Post edited by setzer808 on
  • jrausch
    jrausch Posts: 510
    edited May 2003
    Some tube sets have higher scan rates like Sony's wega. I believe Component (RGB) inputs on your set is the only way to get a progressive signal from P-DVD. This will also give more brilliant colors. Check your manual, it may tell you what the lines of resolution are for your set. Mantis may have more on this.
    "The only way to get rid of a temptation is to yield to it."
  • setzer808
    edited May 2003
    The set does indeed have Component RGB inputs available.
    Polk CS245i Center
    Polk RT55i Mains
    Polk RT25i Rears
  • Ron-P
    Ron-P Posts: 8,520
    edited May 2003
    Then it should benefit from a progressive player.
    Peace Out~:D
    If...
    Ron loves a film = don't even rent.
  • setzer808
    edited May 2003
    Thanks for the replies, now I just gotta convince myself to shell out the money on a new DVD player...glad to see that progressive scans can now be had for as little as $99.
    Polk CS245i Center
    Polk RT55i Mains
    Polk RT25i Rears
  • Ron-P
    Ron-P Posts: 8,520
    edited May 2003
    Don't forget to add the cost of a set of component cables, roughly $75 on up.
    Peace Out~:D
    If...
  • dlew308
    dlew308 Posts: 530
    edited May 2003
    Does having RGB inputs on a TV mean it can handle progressive scan? I have my progressive scan player hooked up to my tv via rgb and turning on progressive scan messes up the picture.
  • ChrisDurano
    ChrisDurano Posts: 372
    edited May 2003
    You need a Digital TV to see progressive scan images. Hooking up your DVD's standard (not progressive) component output to a standard analog TV's component video input will increase picture quality, brightness and color. To get progressive images (60 full frames/sec.) and utilize 2:3 pulldown, however, requires a digital tv. Progressive scan filmlike, with more fine detail and less flicker.
    Home Speakers polkaudio RTi70's (bi-wired), CSi30, FX3000i, PSW250
    Car speakers polkaudio EX 369, DB 650
  • mantis
    mantis Posts: 17,325
    edited May 2003
    Actually I somewhat disagree........
    I have noticed that sometimes when using interlaced players that the composite feed looks the best overall.Due to the better scaler inside the TV.Example Pioneer Elite sets.....enough said.
    Correct,you need a compoment video cable to pass the signal.Only Digial ready or HDTV ready sets can decode the signal.
    I would also suggest you use quality cables for video.
    Dan
  • setzer808
    edited May 2003
    Well, I've sent RCA an e-mail asking for their input also (now to see just how long a reply takes...). I thank all of you for your input so far.
    Shameless Vanity Plug: I've updated my system showcase with pictures of how my system looks with my new TV. :D
    Polk CS245i Center
    Polk RT55i Mains
    Polk RT25i Rears
  • danger boy
    danger boy Posts: 15,722
    edited May 2003
    nice tube TV .. bet it looks great. you must be a gamer. I see nearly every console there on the floor.
    PolkFest 2012, who's going>?
