Blown tweet or crossover or both.
aloutah
I have a tweeter that isnt working in my ls50's. I was going to replace it, but wanted to know if that is all that is wrong. Is there a way to test the other drivers and the crossover to make sure they arent messed up as well? I basically dont want to put too much money and effort into these. If its just a tweeter, thats one thing, but if more needs work, i might pass them on to someone more handy than myself.
Post edited by aloutah on
Have you tried swapping the tweeters to see if the problem follows to the other speaker? That would be the easiest way I can think of.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
It's not that I'm insensitive, I just don't care.. -
Ive never changed a tweeter or driver. How are they connected internally? Is there any soldering involved? Just asking before I try to open them up myself.
That all depends on how they were made, my Monitor 70's tweeters have connectors that you can just pull off and it's out. However, my Monitor 10's tweeters are soldered in. Take the screws holding the tweeter out and gently pull the tweeter out of the speaker, you should be able to tell fairly easily which is the case.
-JeffHT Rig
Blu-Ray- 80 GB PS3
I called polk and they said the monitor 10 have connectors you can just pull off. I unscrewed the tweeter, but still not sure how to pull the connector off. I tried to pull it apart, but didnt want to force it.
some connectors have a small locking tab you can pry up to release the terminal, thats if you see they are not solderedSamsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
If anyone had pictures of these connectors, it would be helpful.
this is a SL5501, but they are the same.
lol, 56k warning
LOL...sorry
I guess someone wanted the driver pic to be up to scale, right ;)DARE TO SOAR:
Your attitude, almost always determine your altitude in life -
yeah...I wanted it to be LIFE SIZE...LOL
Actually, I just linked to the picture on ebay, sorry I cannot delete it.
It was not that big on there...guess it was just a thumbnail.
