Do I need a new driver?
cnoat
cnoat Posts: 315
edited March 2010 in Troubleshooting
Hello all,
I have a pair of rti12's and to be honest they just don't sound right.I put my ear up to them and noticed that the upper minrange just seems to be lagging.But it is movind a pretty good amount.Alot more than the other channel.
I read on someone esles post if you move the driver 180 deg it might help.So I went to do this.As i was doing it I noticed when I manually push the driver I felt a gring for lack of a better term.None of my other drivers were giving me this feeling.Do I need a new driver?
Parasound Avc-1800
Mains-Rti 12 -Parasound 1500a
Center-Csi5-Parasound 1000a
Rears-Rti 8-Parasound 750a
Sub SVS Ultra Tv 12
Diamondback and King Cobra IC's
AQ T4 SC
Post edited by cnoat on
  • AudioGenics
    AudioGenics Posts: 2,567
    edited March 2010
    if you are able to "swap" drivers with a known good one
    that may give you a better indication of whether the unknown one is good or bad.
    if the movement of the cone is not free and easy
    then the voicecoil could be out of alignment,
    it is a tight tolerance
    a 'rubbing" noise will indicate a rubbing coil
    also check continuity and standing resistance with a volt/ohmmeter
    comparing it to a known good driver.
    contact POLK SERVICE if under warranty for replacement
    if out of warranty as a CLUB POLK member ask for the club discount
  • cnoat
    cnoat Posts: 315
    edited March 2010
    Thanks jvc,
    Going to swap right now.Great advice.
    Parasound Avc-1800
    Sub SVS Ultra Tv 12
    AQ T4 SC
  • so_ein_pech
    so_ein_pech Posts: 42
    edited March 2010
    happened to my rt1000i's woofer. apparently this is a pretty common with polks. http://www.oaktreevintage.com/Polk-Audio_Speaker_Parts.htm (see "Note about Polk Audio speakers.")
