Pioneer 21txh running a dynaudio audience 120C
bopicasso
bopicasso Posts: 878
edited March 2010 in Speakers
So Ive been looking for a long time to match my black dynaudio audience 70s with a center channel. Now I finally found a used one on ebay.
Do you think my Pioneer 21txh would be ok powering that 1 4 ohm speaker? I currently only have a 2 channel amp that is powering my 70s.
Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
Post edited by bopicasso on
  • mantis
    mantis Posts: 17,433
    edited March 2010
    It can but get a multichannel amp. The amp section in the 21 is not designed to handle 4 ohm loads. Some older Audience center channel are 6 ohms which will be fine. Check the back of the Center and see what ohm rating it is , it's 4 or 6 ohms.
    Dan
  • bopicasso
    edited March 2010
    Thanks mantis. I just checked the dynaudio site and it is a 6 ohm load. So I guess the pioneer will be able to handle it.
  • mantis
    edited March 2010
    bopicasso wrote: »
    yes it will good luck with your system.
    Dan
  • bopicasso
    edited March 2010
    Well I just won the ebay auction for $290 shipped. I feel like I got a good deal considering how hard it was to find a matching center channel to my black dyn 70s.
    Stay tuned till I receive it!
