Ceiling fan
VR3
I need a cool ceiling fan..
My den has a two blade - which looks like two sling blades....
I found a five blade for one bedroom - the blades are curved inwards - makes it look like a gyro of sorts... looks super cool
I need another cool one - with or without a light
Preferably under 200 bucks --- three blades would be nifty, but Im down for five as long as there is nothing traditional about it...
Any ideas?
Any ideas?
Post edited by VR3 on
Here is the 5 blade I found already -
I can't find a pic of the two blade - but it looks like two sling blades....- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Trey. It's Russ here under f*cktards name. I'll be at your house tomorrow in the morning. Talk to me, Goose!~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
You better be!
*kidney punch*
I have the utility closet doors ready for primer almost --- sanded them down - I put some mud on the back where previous holes were - will sand it down tomorrow and will most likely prime them....
Im going to have to get Lowes to install the master bedroom door, the door jamb is 2.5" bigger on the bottom than the top- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
Vr3MxStyler2k3 wrote: »which looks like two sling blades....
Some folks call it a kaiser blade I call it a sling blade....If you will it, dude, it is no dream. -
Haha - that was 800 bucks over my max...
Thanks for the suggestion though!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I take it you're wanting contemporay/modern look?Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I recommend Hunter, the last 3 I installed needed no blade balancing--for anyone who has installed alot of ceiling fans, you know that's rare. I also have a couple of Hampton Bays, they did require balancing, but ran very smooth after balancing. Of course balancing isn't as important with a flush (direct) mount, but with vaulted ceilings throughout my house, all of mine are on extended "stems."Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Here, these are slick, ceiling fans that look like airplane propellers:
http://www.fanshack.com/store/index.cfm?fuseaction=getproductpg&manuf=craftmade&series=war planes legends
http://www.fanshack.com/store/index.cfm?fuseaction=getproductpg&manuf=craftmade&series=warbirds
All of them are right around $200-$250. Maybe a smidge outside of your price range buy hey, they look awesome! Live a little!Expert Moron Extraordinaire
Probably trying to get away from the 11 year old boy themes.
No, for that, I would recommend this:
http://www.fanshack.com/store/index.cfm?fuseaction=getproductpg&manuf=hunter&series=fantasy flyerExpert Moron Extraordinaire
Here is another one for mouthy crybabies like Demiurge who are too grown up for fun.
http://www.aircraftspruce.com/catalog/pspages/propellor_fans.php
$336 but it's an actual spruce blade, same thing on an airplane.Expert Moron Extraordinaire
homedepot.com and lowes.com
This one is kind of neat. I have it in my rental condo. Moves a lot of air and is very quiet. Blades rotate in opposite directions.
Hampton Bay
http://w02.static-wize.com/photos/large/83457.jpg
I never realized how overpriced ceiling fans were until today. Damn.
I have two I want to upgrade, but now not so much. -
Testing
Testing
Testing -
No kidding, Fanimation tends to have some cool ones, but fetch serious coin.
Regards,
Mike -
If you go to Home Depot and aren't overly picky you can easily get out for under a hundred bucks.If you will it, dude, it is no dream. -
Tower Boss wrote: »
Regards,
Mike
I want this one....Testing
Testing
Testing -
bobman1235 wrote: »If you go to Home Depot and aren't overly picky you can easily get out for under a hundred bucks.
I'll have to do that. I've been trying to avoid that store because it's too easy to spend money and my house has been maintenance free so far. -
This is my ceiling fan!
It's mounted in my ceiling!
http://www.airscapefans.com/products/Shop/Whole-House-Fans/Whole-House-Fans/AirScape-1.0-WHF-Whole-House-Fan
It was $535 shipped and about 4.5 hours of installation on a Saturday. It'll pay for itself in less than two seasons.
My ceilings are only 8 feet so ceiling fan options are very limited and not really worth while with such low ceilings.Expert Moron Extraordinaire
Trey...if you put this pick this one for your bedroom, you'll have to bolt the furniture down.Vr3MxStyler2k3 wrote: »Here is the 5 blade I found already -
