SDA-1c or original SRS-2 for 2ch stereo??
Malcolm G
Malcolm G Posts: 21
edited March 2010 in Vintage Speakers
How does the Sound Quality of the original SRS-2 compare to SDA-1c?
This is for music (2ch stereo; no HT) in a large room. I want the best SQ, not concerned about volume levels.
Post edited by Malcolm G on
  • ben62670
    ben62670 Posts: 15,969
    edited March 2010
    The SRS-2 if it is pin blade.
    Ben
  • gdb
    gdb Posts: 6,012
    edited March 2010
    I asked the same question a couple of years ago and was told the larger passive radiator in the SRS2s made them a slightly more desirable choice. the SRS2s are also a lot rarer it seems. I was very lucky to get a great price on a pair of pin/blade SRS2s from a member here and was very happy to make a day-long trip through Virginia to get them! Never heard any 1Cs, but as long as I have The SRS2s....I don't think I need to try the 1Cs. Now SRS2.3TLs, thats another story. I'd love to find some of them for a comparison!:)
    billbillw Posts: 7,559
    edited March 2010
    They would both be very good choices and it would be hard to go wrong with either. However, for best sound quality, you should plan on upgrading the tweeters and rebuilding the crossovers.
    When Ben said that Pin-Blade SRS-2 is preferable, I think its because the Pin-Blade SRS uses a crossover that is much cheaper to rebuild than the blade-blade version (due to the number and size of capacitors that need to be replaced).
    I have a set of SDA-1C and I'm very happy with them.
    heiney9 Posts: 25,440
    edited March 2010
    Either would be great. The SRS2's are a bit more difficullt load to drive and if you ever want to use a non-common ground amp or mono blocks you can't with the SRS2's but you can with the 1C's.
    IMHO, the 1C's are the gem of the entire line. They are the most popular, easier to drive and can be set-up in medium to large room. Are easier and less costly to modify.
    That all being said, go with the ones that are closest to you and/or are in the best shape as you won;t go wrong with either one of them.
  • ben62670
    edited March 2010
    The SRS-2's are just as easy to drive if They are pin blade. It uses the same XO as the 1C's.
    Ben
  • gdb
    gdb Posts: 6,012
    edited March 2010
    Why wouldn't the pin/blade SRS2s be able to use the A1-A cable and non-common ground or mono-block amps ?:confused: Mine have dual sets of binding posts so I presume that they can be bi-amped at least.
  • ben62670
    edited March 2010
    The Pin Blade SRS-2's can use the A-1
    Ben
  • gdb
    gdb Posts: 6,012
    edited March 2010
    Thanks Ben, I had a hunch that they could.:)
  • bluecomet
    bluecomet Posts: 1,118
    edited March 2010
    I have both the SRS 2 pin/blade version and the SDA 1C's. The SRS 2's are basically SDA 1C's on steroids. If you like the sound of the SDA 1C's, then you basically get more of what you like with the SRS 2's. It has a bigger base sound and wider soundstage but the sound is very close sonically to the 1C's. The replacement RDO's made a huge difference with my SRS 2's. It could be that the SRS 2 tweeters the SL2000's degraded more than the ones in my SDA 1C's. Either way you can't lose on whichever you choose. The SRS 2's are 6 ohm speakers so you can run them on newer AVR's if you wanted to and incorporate them in a HT system. I use to own the original SRS 2's and they were 4 ohm speakers and were harder to drive. The mid range was not as good as the pin/blade version. I believe the pin/blade version uses different drivers. I don't see myself selling either of my SRS 2's or SDA 1C's. They are both keepers. Heiney9 is right. Locate either set of speakers in the best shape you can find and you will be pleased.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • Larry Chanin
    Larry Chanin Posts: 601
    edited March 2010
    heiney9 wrote: »
    Hi,
    Could you please elaborate? Do you mean that some of the 1C's can be used with the A1 interconnect? I have a 1C with a blade-blade connection so am I correct they are not suitable for use with the A1 interconnect and therefore can't be used with mono blocks?
    Thanks.
    Larry
  • ben62670
    edited March 2010
    Are you sure they aren't 1B's?
    Ben
    edited March 2010
    Hi,
    Thanks.
    Larry
    Early 1C's can't be used without calling Polk for a work around to use the AI-1. I'm running out the door but I promised another member the serial number for the L & R 1C's that can use an AI-1 w/o furthur modification. When I get back I'll post them here.
  • Larry Chanin
    edited March 2010
    ben62670 wrote: »
    Hi Ben,
    Yes, pretty sure they are 1C's. I'm the original owner.
    Larry
  • ben62670
    edited March 2010
    There were a few transitional models that had the Blade Blade connector.
    Ben
  • Malcolm G
    Malcolm G Posts: 21
    edited March 2010
    Did the original SRS-2's come in both blade-blade and pin-blade configurations?
    If the crossovers are different I'd imagine the sound is somehow different, and it sounds as though the blade-blade is inferior?
    If the crossovers in the sda-1c and pin/blade srs-2 are identical, are the drivers also identical; the only differences being cabinet size and PR size?
  • Malcolm G
    Malcolm G Posts: 21
    edited March 2010
    Has anyone taken the guts of an sda-1c, bought 15" PRs and do a diy larger cabinet??
  • Larry Chanin
    edited March 2010
    ben62670 wrote: »
    Hi Ben,
    Yes, I also have a pair of SDA-CRS+ that also have blade-blade connections.
    Larry
    edited March 2010
    The AI-1 interface can be used only with serial numbers greater than the following
    1C's Left channel #5975 or greater; Right channel #6001 or greater
    Some early units of SDA 1C and all units of 2B require plug adapters and some internal modifications to the x-over
    The affected 1C's are Right channel #6001 thru 6310 & #6501 thru 6678
    Left channel #5975 thru 6370 & #6532 thru 6656
    So any any serial number less than stated in the 1st paragraph can NOT use the AI-1 and those serial numbers listed in the 2nd paragraph can use the AI-1 but need an plug adapter and internal x-over mods. I am assuming because of the blade/blade IC.
    This info comes straight from the SDA Compendium 2nd ed. If you have questions it's best to call Polk customer service.
    Hope this helps
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2010
    Signature Reference Series, period.
    My favorite SDA, the SRS 2.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited March 2010
    Malcolm G wrote: »
    That's an interesting idea...Do the 1C's and SRS 2's use the same MW's? What about the XO's? Same or different?
    heiney9 wrote: »
    heiney9 wrote: »
    Hope this helps
    Great information Brock! This thread has made me a think of a potential snag to some of my plans...
    I've been planning on upgrading my 2A's to TL status, since it was determined that it was possible in this thread.
    I've been thinking about guinea pigging my 2A's for this experiment...but now I'm rethinking that. The 2A's are blade/blade, so they can't use the AI-1 IC. As far as I know, there isn't any way to use mono blocks with them...which could be a problem in the future. There are at least a few different mono blocks that I'd like to try eventually down the line...and with the 2A's, that wouldn't be a possibility.
    So, I think this brings me back to wanting a pair of 1C's...the indecisiveness strikes again!! Some LSi9's or LSi15's will be coming along before I take my next step down SDA Avenue though. I think 1C's are still a couple years off for me.
    When I'm ready to upgrade to 1C's, I'm definitely going to try and track down a pair of 1C's that can use the AI-1 without requiring modifications. These are the ones that had a two piece crossover, correct?
    Just to be clear...
    Left channel 1C's with a serial number between 6370 and 6532, or greater than 6656, do not require modification to use the AI-1.
    and...
    Right channel 1C's with a serial number between 6310 and 6501, or greater then 6678, do not require modification to use the AI-1.
    Did I get that right, or did I read it completely wrong?...lol
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    edited March 2010
    Malcolm G wrote: »
    Why make Franken-Polks? There is more than just a cabinet to SDA's.
    The 1987 version of the SRS2's uses the same drivers as the 1C's. But, I believe the x-overs are different. What you suggest is way more work and the difference wouldn't be worth the effort.
    Either find 1987 SRS2's or be happy with 1C's.
    IMO
  • inspiredsports
    inspiredsports Posts: 5,502
    edited March 2010
    I remember auditioning both the SDA-2B and SDA-1C numerous (probably 10) times at my local Audio Craft store back in 1987 before deciding on the 2B's. I felt the sound was very similar and went with the smaller, more affordable 2B.
    In 2008 I "TL'd" the 2B's, bought a pair of 1986 SDA SRS 2's, and then also found a way to "TL" the SDA SRS 2's as I could not "go back" to less revealing SL2000/RDO-194 sound after hearing the RDO-198's in the TL'd 2B's.
    It's coincidental that just this morning I was A/B-ing the two sets. The SDA SRS 2 has a vastly wider sound-stage and subtly fills the room with bass in a way the 12" passive simply can't adequately compete.
    The 4 ohm 1986 SDA SRS 2 is harder to drive than the higher impedance 1987 model, and the low pass cap values are large, but the sound quality is stellar. As a side note, if your amp is stable driving into a 4 ohm load, there is the benefit of the added wattage potential at the speakers. It is true that being blade/blade, you can't use the AI-1 to accommodate non-common ground amps.
    I'm not sure what drove Polk from using four 4 ohm MW6509's per cabinet in 1986 to the 2 each 8 ohm MW6511/MW6510 configuration of 1987, but I'm guessing it might have been a cost consideration.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
    Toolfan66 Posts: 18,066
    edited March 2010
    Isn't the difference in using the A1 interface in the 1C's dependent on whether you have the 2 piece crossover or the 1 piece crossover the same as what serial numbers you can only use??
    I have the 1 piece crossover, and I will check my serial numbers when I get home..
    Can someone post a pic of a SRS-2? i know what a 2B looks like and I get the other 2's mixed up sometimes..LOL
    edited March 2010
    What I wrote in the above post comes directly from Raife (Darqueknight) as it was printed in the Compendium Ed. 2. I'm sure his info comes directly from Polk and that's all I can say.
    If anyone has questions beyond that, I'd recommend they contact Polk customer service. If your serial numbers are beyond the ones listed you should be fine. One could loosely deduce that info about 1 vs. 2 board x-over but I have no idea if there is any correlation. It make sense, but I can't state that as a fact.
  • inspiredsports
    edited March 2010
    . . . can someone post a pic of a SRS-2? I know what a 2B looks like and I get the other 2's mixed up sometimes. . .
    Here are a couple of quick snapshots of the 1986 blade/blade SDA SRS 2. 1987's look the same, but have different crossovers and MW's.
    142 lbs each, 50" high X 20-11/16" wide X 12-11/32" deep.
    NAD SS rigs w/mods
    GIK panels
  • Backtothe80s
    Backtothe80s Posts: 45
    edited March 2010
    I have 2 pairs of the blade/blade SRS 2s, and am running one set with a Carver TFM-55x (at between 500-600 watts/channel into 4 ohms), and the other with an Adcom GFA-555 (at about 325 w/c into 4 ohms). The added power of the Carver definitely makes a difference, particularly with bass at higher volumes.
    While I have upgraded both sets with RD0194 tweeters, both have the dual X/O set up, and I haven't done anything to the crossovers yet except to replace the polyswitches. This thread serves as a reminder that I need to, at the very least, do the X/O upgrades to replace all caps and resistors.
    If I want to go to a full TL upgrade, will it be worth my time and money? It would require all new MW's, wouldn't it?
  • stubby
    stubby Posts: 723
    edited March 2010
    I am gathering parts for the TL upgrade myself. No, you don't have to replace your midwoofers. Just your tweeters with RDO198's. (and the associated x-over parts!) I firmly believe it will be worth the T&M. I think TL model speakers sound much better than earlier efforts.
    stubby
    SRS 3.1TL
    Harman Kardon Citation 5.1
    Anthem AVM2
  • Malcolm G
    Malcolm G Posts: 21
    edited March 2010
    heiney9 wrote: »
    IMO
    Ben said the crossovers were the same as the sda-1c. I was thinking that after people replace the caps and resistors in their x-overs, rewire with silver cable and special Cardas spade connectors, upgrade the tweeters, replace a locked driver or two, pad down the driver frames with Dynamat, seal everything up with rope caulk, make new cloth sides and wood caps and balance everything on gel discs for better bass... the only thing I haven't seen anyone mess with is a better cabinet. So if I never found an SRS-2, I figure I could eventually make one out of a sda-1c... Those cabs don't look all that complicated (though i haven't seen the internal bracing).
    All that said, yes I'd rather buy one.
    Sounds like either the SDA-1c or SRS-2 would be fantastic choices.
  • inspiredsports
    edited March 2010
    Hi Bruce, I've answered your PM and will help any way I can. Absolutely worth it in my humble opinion.
    It can be done with just the top 2 tweets being replaced with RDO-198's and 2 5.8uf Sonicaps bypassing a 2.7ohm resistor in the high pass half of the 2 piece crossover if budget is a concern. MW's stay the same.
    A full crossover rebuild with Sonicaps (or better) and replacing all 4 tweets yields stellar results.
    NOTE: I have the 1986 4 ohm blade/blade 2 piece crossover SDA SRS 2's with 4 MW 6509's per cabinet. A method to TL the 8 ohm 1987 pin/blade 1 piece crossover SDA SRS 2 with MW6511's/MW6510's has not been conquered yet. If someone does figure out the 1987 mod, I think it will also translate to the SDA 1C, but at this point we are only talking 1986 blade/blade SDA SRS 2.
    NAD SS rigs w/mods
    GIK panels
  • gdb
    gdb Posts: 6,012
    edited March 2010
    "NOTE: I have the 1986 4 ohm blade/blade 2 piece crossover SDA SRS 2's with 4 MW 6509's per cabinet. A method to TL the 8 ohm 1987 pin/blade 1 piece crossover SDA SRS 2 with MW6511's/MW6510's has not been conquered yet. If someone does figure out the 1987 mod, I think it will also translate to the SDA 1C, but at this point we are only talking 1986 blade/blade SDA SRS 2."
    I hope that a method for "TL'ing" the pin/blade models can be worked out someday!:(
