Carver C-9
bhooramo
bhooramo Posts: 1
edited April 2010 in Troubleshooting
It seems as if my carver C-9 is not working.
The whole setup used to work as expected. After doing some troubleshooting with my pre amp. tape output and input, it seems as if the C-9 is not working.
Is there anything to check internally? The power light is on.
Thanks.
Post edited by bhooramo on
  • helipilotdoug
    helipilotdoug Posts: 1,229
    edited April 2010
    Hey bhooramo, try joining this forum:
    http://www.carveraudio.com/index2.htm
    There are a lot of very good Carver guys there who could maybe give you some help. Also there are a couple of Carver repair services listed there too. Good luck.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • weitrhino
    weitrhino Posts: 34
    edited April 2010
    Open her up and have a look see. Honestly, at the prices a C-9 can be had, you might just as well get another one.
    _________________
    Carver Tube Monoblocks
    Sunfire Classic Vacuum Tube Control Center
    Carver Amazing Platinum Speakers
    Oppo BDP-93
    Carver TX-11b
  • Fongolio
    Fongolio Posts: 3,516
    edited April 2010
    Check for bulged caps. At 25+ years old though, even without looking bad, the caps could be going going gone. Are you just not getting the holographic imaging like you used to? Welcome to Club Polk by the way.
    Kelvin
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
