Most Cost Effective Audio Upgrade BY FAR!!!
falconcry72
CLEANING OUT YOUR EARS!!!
Not even joking. If you've never experienced the overwhelming sensation of having your ears cleaned out really well, you owe it to yourself. I have a friend who almost passed out after having his ears cleaned out; he said he could not believe the difference it made in his hearing and he almost hit the ground. It wasn't that dramatic for me, but it made a huge difference in my hearing, especially for my perception of higher frequencies. Get ready to get sick of those sl2000's if you like'em now!!!
I did mine be soaking Murina (hydrogen peroxide solution) in my ear for several minutes with my head cocked sideways to keep it in, and then blasting out the wax with a syringe-looking water-shooter; you could use one of those blue rubber ball things too. The results in the sink spoke for themselves :eek:
Seriously though, give it a whirl; it may just blow your mind!!!
Post edited by falconcry72 on
Annual event at the Dr. Great feeling.Michael
NORTH of 60° -
I get the wax blown out of my ears every year. It is interesting on how the audio changes from before and after.
BillMy 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012 -
I clean my ears out with Debrox about once a month or so. I've had chronic ear infections for basically my entire life though...and the doctor has always recommended Debrox to me. Works very well...
Sometimes you look at what comes out...and can't even believe it!The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
This is totally not what i expected when i clicked on the thread. lol.
Makes me wonder if I should clean my ears just due to the opinions in this thread.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
:cool:packetjones wrote: »This is totally not what i expected when i clicked on the thread. lol.
packetjones,
when I said "you owe it to yourself" I wasn't kidding. I never thought that my hearing was in any way impaired, I'm a musician, and when I cleaned'em out for the first time it was seriously like night and day with the treble. :cool: You might as well try it; it can't hurt (unless you are too aggressive with the plunger)
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
Something I have wanted to try for a long time as I definitely have experienced some roll off and I am sure other things. Are these common safe practices...as I did some research on candling before and it is quite controversial.
Thanks,
MikeModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
Midnite Mick wrote: »Something I have wanted to try for a long time as I definitely have experienced some roll off and I am sure other things. Are these common safe practices...as I did some research on candling before and it is quite controversial.
Thanks,
Mike
I know people that have done this procedure successfully for years and I know some that have damaged their ears. Sorry, I am not an ENT, therefore I get a professional to do it.
PS - I don't pull my own teeth either.Michael
NORTH of 60° -
janmike,
thanks for bringing up the safety issue. I have never done the 'candle burning' technique as mentioned above, so I can't vouche for or against it. As for the technique I mentioned, I do advise to be careful, but I am not a doctor and for all you know I may be a raving luny, so take your own ears into your own hands, but If you're careful I think you'll be alright. Here's the point:
If you can afford it: let a doctor do it!!!2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Just out of curiosity, what would that procedure cost in the USA. It's like $10 here if you do not have insurance. I actually asked last year what the fee was for folks with no coverage.Michael
NORTH of 60° -
I found the best way was to simply remove my head from my ****. The muffled sound went away instantly, but the smell took a bit longer.:eek::p:DThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Is this something any GP does or is this something one would go to a hearing centre for?
Thanks,
Mike
PS. I just turned 40 and I don't even have a personal physician nor do I ever frequent a doctors office. Probably, not the smartest thing I guees.Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Usher CP 6311
I had mine cleaned out by my doctor last Wednesday (it was time for my annual checkup). And as usual, big plugs of wax came out of my ears. Yes, it does make a difference.
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
I had a serious sinus infection years ago. The Doc...lifted out a wad of impacted wax from my left ear and turned to me and said "you should hear a lot better out of that ear now"....NOT--it made ABSOLUTELY NO DIFFERENCE....so either I'm going deaf or I've got super hearing? Wax has 'never' affected my hearing. Why, I don't know!
Midnite Mick wrote: »Is this something any GP does or is this something one would go to a hearing centre for?
Thanks,
Mike
Not wise....forget about your ears...you're now getting close to the age where a physical a year is almost a requirement!
I flush my ears with warm water every morning in the shower. Fill with warm water, wait a minute, tip head to pour out, repeat. YMMV but I used to have wax plugs removed every year by a physician and now I never have any wax buildup. And yes, when I used to have the wax plugs, it made a big difference in my hearing when they were removed.
I was going to start this with "This may sound silly." Then it occured to me that I'm responding to a thread about ear wax removal as a cost effective audio upgrade and that statement would be redundant.SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
1000VA Dreadnought
Dared SL-2000a (Siemens & Halske TM 12AT7WA's, Brimar 5Z4G)
Jolida JD-100a (Sylvania BP TM Gold Brand 5751's), NAD C275BEE, Blue Jeans
RTiA3, Onkyo TX-SR605 -
I dig in my labs ear with a heroin spoon, roll little balls of dog ear wax, and stragetically implant them in my ears. I get SDA walking around the room.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
I remember how odd it was to actually hear my t-shirt sliding on my shoulder as I walked to the car. It was weird ....then my wife shut the car door , BOOM ! OUCH!
The doctor had played hell getting the plug and finally gave up , gave me a small syringe and some wax softener and told me to use some hydrogen peroxide to help loosen it , "Don't be afraid of blasting it hard , it will feel weird , but it won't damage it".
When it finally broke free , it looked like my ear ralphed in the sink .... nasty.
Unbelieveable amounts of junk ..... but damn could I hear !Plasma : Panny 54G25
Receiver : antique Sony :mad:
BD/DVD/CD : OPPO BDP 93
Fronts : Polk Monitor 10B
Center : CSi5
no rears yet , no sub ... Looking at RTia3's first then 9's and a NAD T 747 ... maybe -
I've never had my ears cleaned professionally and have never had a problem hearing and I work around fighter jets.****Home Theater****
Integra DHC-40.1
Rotel RMB-1075
Fronts 265-RT
Center 265-RT
Rears 65-RT
Sub BIC H-100
****VIDEO****
Projector Epson 8700 UB
BLU-RAY Sony BDP-S1000ES
****2-Channel****
Magnepan SMGa
Sub ED A3-250
AMC 3100a
TT Music Hall 2.2
Bellari VP 130 Phono Pre
Grant Fidelity Tube DAC-09
Sirius Stiletto 2 -
i have always thought this would help and now i may seek a doctor next week to have it done..Room 1:
ONKYO TX-SR608
Polk Complete RT 5000 System
Polk RT3000p's Front
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk RT2000's Front Someone Please Sell Me Some RT3000 so I can have a second RT5000 setup !!!!
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear -
I used to get ear infections several times a year, which was costing me lots of money. The last time, the doctor put this wick thing in my ear and told me to leave it in for the week... and it didn't seem to do anything but make it hurt worse. After 3 days, I got desperate and hosed it out with warm water and a baby syringe... and as soon as all that crap came out of my ear, the pain was gone. Now, I hose out my ears every once in a while and haven't had a single ear infection since.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
Doctor only.
Yes, good idea.
I did the peroxide thing once and ended up with an ear infection.
That's why i would recommend doctor only.Onkyo TX-NR636
Main - polkaudio Monitor 60's
Center - polkaudio CSI A6
Sub - polkaudio PSW10
Sub2 - polkaudio PSW505
Surrounds - polkaudio Monitor 40 series II
Front Height - polkaudio Monitor 40's
Audio Outdoors
Pioneer VSX 406 - polkaudio Atrium 5
Shed
Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
Shed 2
Nakamichi soundbar -
I clean my ears with Q-tips very carefully each time I shower however, never put any solution in your ear. Let the doctor do it. I know this because I've have an ear problem since childbirth and the doctors have always told me that ear infections are very easy to produce by putting anything, including a finger in your ear.
I'm able to use the Q-tips cause the doc had trained me on how to do it without causing any damage. -
Well I have to admit that no one should stick anything in their ear without prior doctor approval and instruction, you only have one set of ears and dont get a second chance if you screw up and damage something
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all -
I keep my ears pretty clean, but after all these years in a manufacturing enviroment, the damage is already done. I wear ear plugs now for certain things, but with the Tinnitus, I will never have the "Golden" ear.
BuckeyeTim wrote: »I keep my ears pretty clean, but after all these years in a manufacturing enviroment, the damage is already done. I wear ear plugs now for certain things, but with the Tinnitus, I will never have the "Golden" ear.
I get bouts of that from time to time; I hate it. Is yours constant? -
I gas up my ears on a regular basis and add Rain-X as a precaution just in case. When times get hard on hearing, I blast a jet of air from the compressor straight into them at a rate of 230psi. That clears everything out including a percentage of my brain.....but I can hear well.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
You're a nut boy! -
i may try that....Room 1:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear -
[QUOTE=hearingimpared;1304769 I'm able to use the Q-tips cause the doc had trained me on how to do it without causing any damage.[/QUOTE]
Nice to know you been signed off on Q-Tips. Truly a lost art. -
i had my doc remove the wax from my ears one time.. best thing i have ever done. my hearing was so clear aftewards. i mean, i could hear things farther, clearer, cleaner, and the treble i was missing was back.
I have tried it several times at home with the same procedure.... and i could not duplicate the deep wax cleaning the doctor did.
the stuff/wax that comes out is gross-a-rama though :eek:
I wish I could deep clean my waxy ears out the same way my doc did.. i would do it once a month if I could.
the rush of warm water flushing through your ear is very odd feeling though. but damn, I could hear a lot better.. and never realized how much i was missing.. just due to wax. which we all have.PolkFest 2012, who's going>?
