Panasonic BD55k blu ray player 7.1 ch analog outputs
danger boy
danger boy Posts: 15,722
edited March 2010 in For Sale (FS) Classifieds
This was my first blu ray player, I replaced it recently. The player is in great condition. Comes with remote and original users manual. Not sure if I can find the original box though.. i'll have to do some diggin for it.
So much has been written about this panny. google Panasonic DMP-BD55 and get your read on. I copied and pasted some of the info. For those people who need the 7.1 or 5.1 analog outputs, this would be a good player for you. It was written up left and right for it's impressive analog processing abilities.
Here is the deal, the deck is $115, you pay shipping and I throw in a sealed non blu ray DVD of Star Trek movie (the most recent one).
My zip is 99223, Spokane, WA.
once boxed up.. I think it will weigh in right around 10 - 12 lbs. I will ship it Fed Ex ground.
Any questions... post them here.
Post here your interest in buying it too.
Product Features
* Blu-ray Player
* BD Live / 7.1 Lossless Decode and Analog Output
* VIERA Link: Operate with your VIERA Remote Control
* SD Card Slot
Technical Details
* Brand Name: Panasonic
* Model: DMP-BD55K
* DVD Type: Blu-Ray disc player
* Audio Output Mode: Surround Sound
* Surround Sound Effects: Advanced Virtual Surround Sound (V.S.S.)
* Form Factor: Tabletop
* Built In Decoder: Dolby Digital Plus, DTS-HD decoder, Dolby TrueHD, Dolby Digital, DTS decoder
* DVD Media Loading: Tray
* Color Name: Black
* Width: 16.9 inches
* Depth: 9.5 inches
* Height: 2.2 inches
* Weight: 5.7 pounds
The BD35 and BD55 both feature an HD Audio Decoder (Dolby TrueHD, Dolby Digital Plus and DTSTM-HD Master Audio Essential), delivering 7.1-channel surround sound through a 7.1-channel receiver equipped with an HDMI terminal. The DMP-BD55 features high-end audio components and can also output analog signals for 7.1-channel sound, so even receivers that are not compatible with HDMI can produce the newest 7.1-channel surround sound.
Both models are equipped with an SD Memory Card slot that makes it easy to transfer images from an HD camcorder or digital still camera that uses SD Memory Cards and are compatible with Panasonic’s VIERA Link function so they can be operated by the VIERA HDTV remote control.
The combination of a Panasonic Blu-ray player, Home Theater audio system and a VIERA HDTV converts the home entertainment experience into a true-to-life cinematic experience. Consumers can now view and enjoy movies the way the film maker intended -- in stunning High Definition video and audio – right from the comfort of their own home.
True-To-Life Colors
The PHL Reference Chroma Processor Plus video processor was developed after more than 15 years of collaboration between Panasonic Hollywood Laboratory and professional cinema studios in Hollywood. With PHL Reference Chroma Processor Plus, users viewing content on Blu-ray Discs enjoy crisp, vivid colors that are extremely close to the original. A high-precision 4:4:4 function creates video signals in which each pixel of the signal from the Blu-ray Disc is color-compensated, so when the player is connected to a Panasonic VIERA HDTV, the colors are even sharper and more vivid.
UniPhier System
UniPhier is a Panasonic-created system LSI developed by applying 45-nanometer processing to a consumer product – a world’s first. This single-chip integration technology also contributes greatly to the BD35’s world's slimmest height of 49mm.
Specifications
VIDEO
PHL Reference Chroma Processor Yes
P4HD (Pixel Precision Progressive Processing for HD) Yes
Precise Pixel Generation: Yes
16-Level Motion Detection w/ Pixel-Based Motion Adaptive Yes
Diagonal Processing Yes
3:2/2:2 Pull-Down Progressive Processing Yes
i/p Conversion for 1080p 4 Playback Yes
Up-conversion to 1080p 5 Playback Yes
Video D/A Converter 148.5MHz/12bit
Progressive Scan Yes
Digital Noise Reduction 3D-NR/Integrated NR
1080/24p Playback Yes
Deep Color Yes
x.v.Color Yes
Picture Mode Yes (Normal/Soft/Fine/Cinema/User)
Picture Adjustment Yes (Brightness, Color, Contrast, Sharpness, Gamma Correction)
AUDIO
Audio D/A Converter 192kHz/24bit
Dolby Digital/Dolby Digital Plus Decoder Decode and Bitstream output
Dolby True HD Decoder Decode and Bitstream output
DTS/DTS-HD High Resolution Audio Decoder Decode and Bitstream output
96kHz Surround Re-Master (for all formats)
Advanced Surround (V.S.S.) Yes
Night Surround Mode Yes
Dialogue Enhancer Yes
Dynamic Range Compression Yes
Audio S/N 115dB
Dynamic Range 100dB
CONVENIENCE
Super Hi Speed Scan Yes
Audio/JPEG Navigation Menu Yes
VIERA Link (HDAVI Control 3) Yes
INPUT/OUTPUT
HDMI: Support features: Deep Color, x.v.Color, High Bit Rate Audio
Component Video Out (Y, PB, PR) Yes
Video Out Yes
7.1ch Audio Out analog
2ch Audio Out No
Digital Audio Out 1 optical, 1 coaxial
SD Memory Card Slot Yes
Ethernet for Network Yes
FORMAT
BD-ROM Playback BD-Live
BD-RE / BD-RE DL BD-MV (BD-RE version3), BDAV (SESF), JPEG (HD)
BD-R/BD-R DL BD-MV (BD-R version2), BDAV (SESF)
DVD Playback DVD-Video
DVD-RAM Playback DVD-VR, JPEG (HD), AVCHD
DVD-R/-RW/-R(DL) 1 Playback DVD Video, DVD-VR, AVCHD, DivX® (DVD-R/-R DL only)
+R/+R(DL)/+RW Playback DVD-VR, AVCHD
CD, CD-R/-RW 2 Playback CD-DA, DivX (CD-R/-RW only), MP3 3 (CD-R/-RW only), JPEG (HD) (CD-R/-RW only)
SD Memory Card AVCHD, JPEG (HD)
POWER
Power Source AC 120V, 60Hz
Power Consumption21W (approx)
DIMENSIONS
(H x W x D) 23/16 inches x 1615/16 inches x 913/16 inches
Weight 5.7 lbs
Product Description
PHL Reference Chroma Processor Plus is a high quality image-processing technology developed by Panasonic to precisely process each pixel of the Blu-ray Disc video signal in the vertical direction. It reproduces color data with twice the accuracy of conventional systems to keep colors faithful and sharp. P4HD processes more than 15 billion pixels per second and applies the optimal processing to every pixel. So that it can render progressive images superbly, expresses motion smoothly, and draws crisp diagonal lines.
The DMP-BD55 can decode HD Audio (Dolby TrueHD, Dolby Digital Plus and DTS-HD) and output 7.1ch digital audio signal. The resulting audio is studio master quality sound. This signal can be connected to an HDMI compatible receiver that does not support HD Audio Codec. Besides, the 7.1-channel analog signal converted by 192kHz D/A converter is transmitted in high quality. This signal can be connected to a receiver that does not support HDMI. BD-Live lets users access to the Internet to download data such as images and subtitles, and to join in quizzes and multi-player interactive games that are linked to bonus movie content contained on Blu-ray disc.
PolkFest 2012, who's going>?
Post edited by danger boy on
  • Joe Humbert
    Joe Humbert Posts: 189
    edited March 2010
    Interested, PM sent.
  • danger boy
    edited March 2010
    I got your PM Joe Humbert and responded
  • Toxis
    Toxis Posts: 5,116
    edited March 2010
    7.1 analog output sure seems to be missing a couple jacks... I have considered going with a Panny player so I don't have to upgrade my receiver... great players
  • jawhog
    jawhog Posts: 444
    edited March 2010
    Last pic shows 2ch/surround back. I think that's rounding out the 7.
  • danger boy
    edited March 2010
    jawhog wrote: »
    yes that's correct. it does have 7.1 ch analog outs. ;)
    and it's still up for grabs. :D
  • danger boy
    edited March 2010
    the panny is still up for sale.
    tough to find a blu ray player with analog outs for this price.
  • ViperZ
    ViperZ Posts: 2,046
    edited March 2010
    Weird that it's still for sale. I really wanted this exact model when I was looking for the blu-ray player.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • danger boy
    edited March 2010
    another pic... this sealed Star Trek comes with the player for free.
  • Toxis
    Toxis Posts: 5,116
    edited March 2010
    I'm tempted... this would save me some bucks on upgrading to a new HDMI receiver while gaining HD audio. I already own Trek on Blu though so that's not a benefit for me. The only reason I'm not jumping on it is because my projector is down so I really need the money to get that fixed instead of buying a new piece of equipment...
    but I could sell my current Denon 2910... dear lord. What to do.
  • Joe Humbert
    edited March 2010
    Toxis, PM sent.
  • danger boy
    edited March 2010
    haven't bumped this in a couple of days.... it's still for sale.
    7.1 ch analog outs.. you can't touch any other blu ray player with analog outs on the market for this price.
  • mantis
    mantis Posts: 17,477
    edited March 2010
    I don't know why it isn't sold. If I didn't just buy a new blu ray player for this kind of money and a free Star Trek disc??? **** easy one here folks. Buy it before someone else jumps on it. Hell I might just because it's such a good deal.
    If you are on the fence about Panasonic , forget all that , their players are top notch and I have installed this very player many times and really liked it. I found it to be the best of it's time in it's retail price range.
    Love this player and the movie.
    Dan
  • Toxis
    Toxis Posts: 5,116
    edited March 2010
    What's the load time like?
  • danger boy
    edited March 2010
    Toxis wrote: »
    in all honesty it will not break any records for load time. it was built in late 2008.. and most players then loaded in about 30 to 45 seconds. seconds.. not minutes. :p
    Mantis is right, in it's day.. it was considered to be on of the best sq and pq decks. it doesn't have the modern day wi-fi streaming of course like all of today's decks do. but it can be hooked up wirelessly if you have a bridge. this makes it very easy to download and install firmware updates.
    for laughs do a search on Amazon for this deck ;) and look at the price there. no, it's not a typo. :eek:
  • Toxis
    Toxis Posts: 5,116
    edited March 2010
    Gonna pass. I don't need it and I'm sure some one here does. Good luck and free bump.
  • vmaxer
    vmaxer Posts: 5,120
    edited March 2010
    how much to ship to 38242??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • danger boy
    edited March 2010
    vmaxer wrote: »
    from me to you looks to be $17 shipping.
  • bsoko2
    bsoko2 Posts: 1,449
    edited March 2010
  • danger boy
    edited March 2010
    not sold yet..
  • vmaxer
    vmaxer Posts: 5,120
    edited March 2010
    payment and PM sent
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • danger boy
    edited March 2010
    SOLD!
    thanks Billy - vmaxer
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited March 2010
    Congrats on the sale guys, glad someone finally picked this thing up.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
