Are NXG speakers any good? Newbee..
Chip_Roberts
Chip_Roberts Posts: 2
edited March 2010 in Speakers
Looking to make my bedroom into a AV room and will be installing ceiling speakers for the fronts and surrounds. Looking spend $200 for the set of four, on a budget and wife does not want see the speakers hanging on the wall or on the floor. NXG speakers seem to be fit based on the budget and the Radio Shack seems to have them on sell. Are they worth anything or should i look elsewhere knowing my limited funds. Thanks for the help. Chip from Tampa...
One NXG example...
http://www.radioshack.com/product/index.jsp?productId=3228861
Post edited by Chip_Roberts on
  • mantis
    mantis Posts: 17,561
    edited March 2010
    I have Installed them in a multiroom job where the customer just wanted back ground music and nothing expensive. We spec'd these in and they did ok. We used a different model which had a back can on it for better sound quality and bass reproduction. I forget the model number.
    For the money they are ok
    Dan
  • broncsrule21@
    broncsrule21@ Posts: 113
    edited March 2010
    I can't comment on the speakers you linked to, but I used to have the 120w 6.5" pro models as rear surounds in my old house. They fit the bill because the house was prewired. i have no complaints. The NXG brand used to be whole sellers only. I see they are being picked up by Ratshack now. For your budget you probably won't be able to do too much better. What other equipment will be used in this A/V room?
    HT-- Denon avr-2808ci,Emotiva UPA-1s, RTi 10's, CSi A6, ERD-1 surrounds, Vizio P50, Yamaha yst-sw300, DVR hr21, 40g PS3, APC-h15
    Downstairs-- Denon avr-3300,Emotiva UPA-2, Toshiba 50" rear projection, Denon 2200 sacd, Emotiva ERM-1s, small Yamaha sub
  • Chip_Roberts
    edited March 2010
    Actually, I ended up ordering monoprice ceiling 8” angled and 8” rears plus their in-wall center. Total to the door about $220 for all five. I understand quaintly aspects compared to higher dollar ones but will try to get the most out of them. “mdf” box in ceiling but not sure on the center just yet. The monoprice speakers get okay reviews on the AVS forum and again, going for a budget set up. Does anybody have experience with these? I will post an update once installed...
    http://www.monoprice.com
  • concealer404
    concealer404 Posts: 7,440
    edited March 2010
    How'd you manage that? I thought monoprice was down?
