Audio Cuts-out with Comcast Cable Box/Receiver
Brian131
I know that there are others who have had this problem, but what's the best and most effective remedy? My rig is not the most extreme but it's sad to me that I spent over 2K on a new tv, receiver, speaker system, and Blu Ray player only to find that when I hook my comcast hd cable box through my receiver and then to the tv via hdmi, the audio cuts in and out. It does it more on some channels than others, but nevertheless is annoying. I still have to use my tv's speakers and can't use the surround sound!
Yamaha Rx V465
Comcast HD Cable Box
Panasonic 42S1
I noticed that there is a usb jack both on the cable box as well as the tv. Are there any updates that I could install to correct this problem?
Yamaha Rx V465
Panasonic 42S1
Panasonic P42S1
Panasonic BD 65P-K
Yamaha Rx v465
Polk Audio Rm75
Polk Psw 505
X Box 360 Elite
Comcast Hd/Dvr
Harmony 510
I strive to be the kind of person that my dog thinks I am.
Panasonic BD 65P-K
Yamaha Rx v465
Polk Audio Rm75
Polk Psw 505
X Box 360 Elite
Comcast Hd/Dvr
Harmony 510
Post edited by Brian131 on
i have a similar problem with my comcast DVR. the signal will pixelate on occasion... and the signal will go to black for about 2 seconds.. the audio and video both drop out.
I plan to call comcast this week and find out what's going on. I pay way to much for cable tv to put up with that problem.PolkFest 2012, who's going>?
For danger boy, it just sounds like you're getting a weak signal to your box, hence the cutouts.
But just audio over HDMI? Sounds like a faulty box to me. You're rentin gthe thing, just try swapping it out for another one. I've done that with various equipment from Comcast and they've never said anything.If you will it, dude, it is no dream. -
I have the same thing happen with time warner dvr box. Not everyday but once in a while the audio and video will cut in and out, mostly on hd channals.panasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one -
I've had similar issues as above. The remedy that has always worked for me was to unplug the box for a few minutes then plug it back in.Parasound P5 Pre
Marantz AV 7703 Pre/Pro
Outlaw 7500 Amp
Marantz SA14s1 SACD/CD
Rega Planar 2 TT
Polk Audio Speakers: LSiM 705 Fronts, LC65FX Surround, LSiM 704c
Oppo BDP-103 -
+1 with Time Warner. I had the signal strength tested by the field tech and he said it has a strong signal. Must be the box or on Time Warner's end.~Dan
Projector: Epson 705HD on 106" DaLite
TV: Samsung 50" Plasma PN50B550
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
Sub: Velodyne Minivee 10
PS3 and Xbox -
I have the same problem with DirectTv HD DVR. The sound cuts out for a split second every now and then just on HD channels. I don't know what the problem is, I just deal with it.It's all in the detail.
:cool:
HT Setup:
Samsung PN50D550
Onkyo TX-SR805
Samsung BD-D6700
Fronts: RTi10's
Center: CSi5
Side surrounds: RC65i's
Rear surrounds: FXiA4's
Sub: Velodyne CT120
Outdoor: Atrium 45's
Pictures here -
lectronicjunkie wrote: »I have the same problem with DirectTv HD DVR. The sound cuts out for a split second every now and then just on HD channels. I don't know what the problem is, I just deal with it.
Me too . . . any answers? -
Guys, I had the same problem with DTV DVR in the past. It has to do with signal locking, and in my case, it was compounded by B&K weak optical input, hence it did that.
http://www.polkaudio.com/forums/showthread.php?t=77093&highlight=optical+coaxial
It's pretty cheap signal amplifier, so what you want to do is to use the optical out from your DVR and use coax input to your receivers. Who knows it might work better for audio.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
lectronicjunkie- I like the rig!Panasonic P42S1
Panasonic BD 65P-K
Yamaha Rx v465
Polk Audio Rm75
Polk Psw 505
X Box 360 Elite
Comcast Hd/Dvr
Harmony 510
I strive to be the kind of person that my dog thinks I am. -
I had some issues with my old box and have noticed an improvement since I upgraded to the newest box.
