RTi70 Replacement Tweeter
jmwest1970
jmwest1970 Posts: 846
edited February 2011 in Troubleshooting
Does anyone know the part number for a RTi70 replacement tweeter?
Post edited by jmwest1970 on
  • kcoc321
    kcoc321 Posts: 1,788
    edited March 2010
    It is the SL6511. I have been looking for one (two actually) for over a month. Polk does have them though. They run $70 shipped "Club Polk price"
  • dbaldus
    dbaldus Posts: 730
    edited March 2010
    Just to be clear, is the "replacement tweeter" you are referring to the exact same tweeter used in the RTi70s or is this an "upgraded tweeter", similar to the RDO's being better replacement tweeters for the SL2000/3000 series on the SDA's?
    If it is really an "upgraded replacement tweeter" as opposed to a replacement part, I may have to check it out on my 70's!
    2-channel
    Squeezebox Touch| MSB Analog DAC | Audio Research Ref 40 Anniversary Edition| Pass Labs X350.8 | Wilson Audio Sasha 2
    Arcam AVR 550 | GoldenEar Triton One | GoldenEar SuperCenter XXL | GoldenEar Aon 3 | JL Audio Fathom F113v2
  • jmwest1970
    edited March 2010
    $140 is almost as much as I have in them. I don't know if it's worth it to upgrade them of put a couple hundred more in and get something new.
  • kcoc321
    edited March 2010
    dbaldus wrote: »
    TheSL6511 is the 'stock' tweeter that came with my RTi70's, at least in mine.
    As far as I know there is not an upgraded version.
    You could try Polk CS, but I seem to remember Kim telling me there was just the one.
  • kcoc321
    edited March 2010
    jmwest1970 wrote: »
    Well, jm, do you only need one, so that is only $70 for some pretty good speakers.
    If you need both, it would cost $140
  • sp13
    sp13 Posts: 2
    edited March 2010
    RD6514-3 is what is on the invoice I have along with the description Tweeter SL6506. I just replaced mine and they worked out great.
  • kcoc321
    edited March 2010
    sp13 wrote: »
    Interesting...So, you got the SL6506's as replacements for what speakers? RTi70's? Cuz I know the SL6506's are the upgraded replacement tweeters for the RT55i's, that is what Kim @ CS told me.
  • puissant
    puissant Posts: 3
    edited October 2010
    I recently bought two tweeters for my RTi70's. The tweeter number is SL6507 and I paid $68.48 each, its the club polk member price.
  • Omega728
    Omega728 Posts: 1
    Directly from Polk:
    SL6511 - Stock
    SL6506 - New replacement part
    SL6507 - Will fit, but sound might not match. So you'll have to replace both tweeters if you go with this one.
    So there you go.
  • steelervic
    steelervic Posts: 142
    i have a 6515 i got as a replacement for rti70's. never used it, its for sale if your interested
  • steelervic
    F1nut Posts: 52,106
    steelervic wrote: »
    Do you have it listed in the Flea Market? If so, just provide a link. Otherwise post an ad as this isn't the place. Thanks.
