Need replacement Driver for RT12
indyheel
I emailed Polk's customer support almost a week ago and still haven't heard back. I have a RT12 driver that "seems" to work fine while playing music (ipod, CD, etc.). But when I play a DVD or Blu-ray, the driver distorts bad during background noise/music. I emailed Polk for a replacement driver and explained my problem but no help yet. Anyone have any ideas where I can get anew driver? By the way since this problem started I've replaced my Receiver and Blu-ray player. Plus I've swapped speaker wires, same issue.
You're better off calling them. Use the number that's located on the top right corner of this webpage. Good luck and welcome to Club Polk!
thanks
Underworld54 wrote: »You're better off calling them. Use the number that's located on the top right corner of this webpage. Good luck and welcome to Club Polk!
+1, calling is way better than E-mailing, there is a pretty slow turnaround on E-mails due to the amount they get I'm sure. Good luck, Polk will take care of you. Welcome to Club Polk, and make sure you tell them you are a member of Club Polk and I think shipping is free?
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
