speaker static
aask87
aask87 Posts: 5
edited March 2010 in Troubleshooting
First of all I am new to this forum and to home audio. I just recently purcased the Polk RM85 Home Theatre System and a Sherwood RD-7503. I have the speakers connected to the receiver with 14 gauge speaker wire. I have a cable box and blue ray player running to the receiver with an HDMI cable and a HDMI cable running to the tv. The probem is when I turn the volume down while I am listening to a source, there is some faint buzzing sound coming from the speakers. Is there a problem with the way I have hooked up the speakers, is it faulty speakers, or is it a problem with the receiver? I really don't know where to start to pinpoint the problem Any help would be greatly appreciated as I am new to this wonder world of Home Audio.
Andrew
Post edited by aask87 on
  • zarrdoss
    zarrdoss Posts: 2,562
    edited March 2010
    It could be a number of things, maybe electrical noise coming from your house wiring. start with a simple set up as possible FM tuner and keep on adding things and keep checking to see when the static comes into play.
  • aask87
    aask87 Posts: 5
    edited March 2010
    Thank You, I will look into that once I get some more free time. Could it possibly be the receiver since it is coming from all the speakers?
  • zarrdoss
    edited March 2010
    yes it could be, but like I said it might be noise coming from your electrical system in your house, all kinds of good stuff.
  • ShinAce
    ShinAce Posts: 1,194
    edited March 2010
    aask87 wrote: »
    If it mostly happens when you play with the volume knob, then I guess you have an old receiver with dirty knobs. They can be cleaned, but never with 100% success.
  • dpowell
    dpowell Posts: 3,068
    edited March 2010
    Unplug the cable box from your receiver and see if the noise goes away. Often that type of noise is directly related to a ground loop. If unplugging the cable box fixes the problem, you'll need to get a ground-loop isolator and put that inline with the coax cable coming into your cable box. The Jensen ISOMAX is highly regarded around here.
    polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
  • aask87
    aask87 Posts: 5
    edited March 2010
    Thanks for all the suggestions. Like I said I am new to the Home Audio thing and so far I am loving my Polk's!!
    tonyb Posts: 33,000
    edited March 2010
    aask87 wrote: »
    Highly unlikely, would gather it's probably a ground loop. Are you useing any kind of power conditioner ? Most ground loops occur by way of cable boxes or having too many things plugged into one outlet. Try unplugging the cable box and see if you still hear a buzz. Make sure the power cables don't run along with the speaker cables also. If you have to cross them,do so on an angle,sometimes they affect each other if run side by side.
  • aask87
    aask87 Posts: 5
    edited March 2010
    Thanks guys, I think we get it solved. I am not hearing static anymore.
  • simpsons
    simpsons Posts: 1
    edited March 2010
    Possibly Good idea just go on and what you think is right ...;)
    Interactive Marketing and Advertising Agency augmented reality
