APC H10 vs H15 Power conditioner
acmf74
acmf74 Posts: 937
edited March 2010 in Electronics
I'm looking for a power conditioner/surge protector and was recommended the APC line. Are the two identical except for the H15 having the led readout?
Post edited by acmf74 on
    heiney9 Posts: 25,432
    edited March 2010
    Yes and the Kva rating 10 for the model 10 and 15 for the model 15.
    try doing a search as this has been covered a few times recently.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited March 2010
    H15 has higher protection power if I'm not mistaken.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • concealer404
    concealer404 Posts: 7,440
    edited March 2010
    The H15 has a higher maximum input current, higher surge energy rating, higher equipment protection policy, etc etc etc...
    It's marketed as an improved H10, and it's exactly that. But it's up to you to decide if it's worth the extra coin. ;)
  • acmf74
    acmf74 Posts: 937
    edited March 2010
    I just bought the H15.
    Thanks all (I think.....whenever I visit here I spend more money) :p
    edited March 2010
    You'll like the display much better on the 15 than the 10
  • concealer404
    edited March 2010
    I'm going to need another one soon... i'll probably step back up to the H15 and move the H10 to HT duty.
    You'll like it. :) Let us know if you hear a sonic difference or not.
    edited March 2010
    acmf74 wrote: »
    Any good deals you've found? I bought mine new, shipped for $99 and I kick myself everyday for not buying 2. Cheapest I've seen a new one recently is around $279-$299.
  • DMara
    DMara Posts: 1,434
    edited March 2010
    I am using an APC S15blk. No sonic difference at all for me.
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
    edited March 2010
    With the H15, I found it to have a blacker background..............it just made things very, very quiet. Also seemed to improve bass a tad and I think because of the dead quiet background the soundstage is slightky better. It definitely improved the cable TV signal.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited March 2010
    Congrats! The APC units are excellent. I'm using an H10 in my 2 channel rig, and couldn't be happier. I'll probably move up to an H15 eventually, and use the H10 on a secondary rig.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • acmf74
    acmf74 Posts: 937
    edited March 2010
    Just got the unit last night and looks like a quality product.
    In the back of the unit there is a Ground Loop connector.
    Is anyone using this and do you use a regular ground wire for it?
    The manual doesn't go into much detail from what I saw.
    edited March 2010
    FTR, I don;t use it.
  • acmf74
    acmf74 Posts: 937
    edited March 2010
    I plugged it in for a few minutes last night and the "Wiring OK Status" light wasn't lit. Not sure if there is a wiring issue but I decided to run a dedicated line from the fuse box to the APC unit. Hopefully this will fix this.
    edited March 2010
    If the light didn't light up.............then yes, there is an issue. Most issues are reversed polarity. A dedicated line is a great idea anyways. So just do that and then use the conditioner
  • mantis
    mantis Posts: 17,394
    edited March 2010
    I just picked up a J15blk last week. It's a really nice unit. It's really long and quite heavy but it has 12 outlets and batter backup which is exactly what I needed. It's maxed out LOL. I slimmed down some of my gear and I still am stacked.
    Dan
