soundbar 360
markblameuser
markblameuser Posts: 1
edited April 2010 in Troubleshooting
main control unit freezes up after turning on intermittently, has to be turned off and back on again, am i doing something wrong?, any tricks or is unit in need of repair
Post edited by markblameuser on
  • Daveandrew
    Daveandrew Posts: 3
    edited March 2010
    Mine seems to be doing the same thing, once it's on for a period of time the sound just quits. The unit doesn't turn off it just quits. I'm using the optical input with PCM.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2010
    D&D,
    I've forwarded this one to Polk Customer Service, stay tuned. The more details, the better, are the problems associated with dvd only?
    Cheers,
    Russ
  • polkednewbie
    polkednewbie Posts: 3
    edited March 2010
    mine would do the same thing bopth while using the DVD and on regular TV watching as well, just no sound all of a sudden. Last night it shut down completely and now when I try to turn it back on the speaker "clicks" repeatedely and the unit does not turn on.
  • Daveandrew
    Daveandrew Posts: 3
    edited March 2010
    Mine shuts off when watching any sources using the optical input. I have noticed that it possibly shuts off when there is heavy bass but I can hardly think that I'm overloading it in anyway. The volume is never above 15 in my little apartment.
  • Daveandrew
    Daveandrew Posts: 3
    edited March 2010
    Lasareath wrote: »
    I'd flip the power switch in the back to off and yank the power cord for a good 5 minutes.
    Do you have it plugged into a surge protector or just directly into the wall?
    (a $5.99 plug strip does not count)
    It's plugged into an APC battery backup, I do believe mine is a heat issue last night when it started acting up I moved a pedestal fan in the living room had it blowing directly across the top and it didn't shut off the rest of the night.
  • Chewbott
    Chewbott Posts: 1
    edited March 2010
    Been following the heat issues with the 360 and raised mine up about 1" above the deck, it is only a week old but seems to freeze up when I go to unused sources, or rapidly between sources. Once it freezes up have to unplug and let it sit for a while. Love the sound and don't want to go thru the hassle of shipping back to Amazon.:confused:
  • Eric W
    Eric W Posts: 556
    edited March 2010
    If you're having trouble with your SurroundBar 360 (or any other of our items for that matter) please contact us directly- 800-377-7655, Option 1. Or email polkcs@polkaudio.com or via the "support" page.
    Generally, if you purchase within the first 30 days, it's best to go back to wherever it was purchased from.
    -Eric
    -Polk Audio
  • asilverwood
    asilverwood Posts: 8
    edited April 2010
    Lasareath wrote: »
    This worked!! Thanks!! Allan
