Wierd Smell from DB1212
Thehippieslayer
I bought a Polk db1212 Enclosure with loaded subwoofer. It is rated for 50-360 RMS watts, 2 ohms... and there on. My amp (Infinity Kappa Five Amp) is labeled as 300 watts RMS (Which, may be wrong and may quite possibly be higher). However, I ran the speaker slow to allow "break-in" and the last week or two I have been not straining it so to say but just playing it. When I get to school (10 minute drive) there is typically a smell coming from the enclosure (Yes the enclosure and not the amp). The woofer is slightly warm. What I am wanting to know, is that smell coming from the subwoofer? Or is it coming from inside the enclosure from like paint warming up? The inside of the vent there is some black paint (thick blotches, may I add). Does anyone have experience with this?
Thanks Cody
Thanks Cody
Post edited by Thehippieslayer on
What does it smell like?
Smell like something burning?Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
Its hard to explain what it smells like. It smells like burning, but it doesn't. It smells like plastic, but it doesn't. Its a sweet smell. Maybe it is plastic burning? Im hoping not; but rather the adhesive/paint the enclosure was made from melting.
Is this a new or used woofer?
New electronics frequently exhibit an electric heat smell until the "new" wears off~TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
What does it taste like?
Sounds like someone left a peanut butter sandwich in your speaker box!lol
