pioneer vsx-1015tx help needed
bassfann
the center channel output has distortion,all others are fine.im gonna send out for repair,just wanted to narrow it down a bit.all transistors "look" ok,but i haven't really dissasembled enough to take readings of them.any ideas ?
Post edited by bassfann on
Do you know for sure it's the center channel amp? Have you swapped a front speaker output with the center playing stereo to feed speaker? Play all channel stereo to rule out decoder?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
disneyjoe7 wrote: »Do you know for sure it's the center channel amp? Have you swapped a front speaker output with the center playing stereo to feed speaker? Play all channel stereo to rule out decoder?
yes,i tried all outputs with a speaker to make sure,and its only on the center channel -
Short of sending it in, not sure what to say sounds like a bias problem or open transistor. I assume it's component electronics and not a chip amp thing.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote: »Short of sending it in, not sure what to say sounds like a bias problem or open transistor. I assume it's component electronics and not a chip amp thing.
i just dont want to send out if its gonna cost me a few hundred.what do you mean a bias problem -
Bias is the voltage needed to conduct a transistor on, if the voltage is not correct your amp sounds like ****. Something in that amp is bad a driver transistor or an output transistor.
If you don't wish to send it out, this is when you can update the receiver. Does this AVR have pre amp outputs if so you could get an amp for the center channel or do all front speakers with a 3 channel amp. It's a little odd that the center channel is bad, even if fixed why couldn't blow it again? Just thinking a loud, an amp could be a sweet update.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
