What about those speaker selectors?
wingzam
wingzam Posts: 201
edited February 2010 in Speakers
Was thinking about picking up a speaker selector so went to ebay and found 8 pages of them!
This would seem to suggest,and partly verify my suspicion that a speaker selector downgrades sound quality.
Your thoughts on this please -
Post edited by wingzam on
  • erniejade
    erniejade Posts: 6,321
    I have heard that most of them change the sound some. I do have a Adcom one at home but, I have never tried it. Some of them I have seen are not rated for big power so be carefull on the power rating on them.
    I am interested in what others thing on this.
  • wingzam
    wingzam Posts: 201
    And i'd be running 400+watts at 4ohms...
  • PSOVLSK
    PSOVLSK Posts: 5,381
    wingzam wrote: »
    I think this takes a speaker selector away as an option for you. If I'm wrong, I may be buying one myself.
    treitz3 Posts: 19,992
    I have a Niles speaker selector switch if any of you are interested. I bought it for an experiment some time back and never got around to using it. First $50.00 plus shipping gets it.
  • wingzam
    wingzam Posts: 201
    PSOVLSK wrote: »
    Maybe someone will chime in with the selector we're looking for.
  • kcoc321
    kcoc321 Posts: 1,788
    treitz3 wrote: »
    Niles makes good ones. Which model is yours Treitz?
  • curved
    curved Posts: 664
    wingzam wrote: »
    What amp are you running?
    Niles has a few different selectors out there.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • wingzam
    wingzam Posts: 201
    I've got an Adcom GFA-5800 and a Kenwood M2..
  • mantis
    mantis Posts: 17,393
    wingzam wrote: »
    What do you want a speaker selector box for? With this kind of power , there is no selector that I know of that can handle that kind of power. I have seen them up to 200 watts handling abilities but not beyond that.
    Dan
    Crap, I just pulled it out and it turns out I have the Niles SVL-1 speaker level volume control. I thought it was a speaker selector switch, my bad.
    Carry on...
  • wingzam
    wingzam Posts: 201
    mantis wrote: »
    Shucks,I just wanted to drag in more speakers and make it "Easier" to play around with all this stuff!
  • erniejade
    I found the model of the one I have adcom gfs-4. Now I have not hooked it up and it has been laying here for about 2 years now.
    The manual says it can take 1000 watts peak.
    http://www.adcom.com/data/manuals/gfs4manual.pdf
    I was going to use it to go between my amazings and my 2.3's on the sunfire sig. amp but I thought th amazings / sunfire sig II combo would not be good on it as the amazings can dip way down.
  • seeclear
    seeclear Posts: 1,244
    Ernie, PM me if you want to sell that. I could be interested. Thanks
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • wingzam
    wingzam Posts: 201
    ...l should be able to find one on ebay,they're cheap enough!...
  • erniejade
    I got mine on ebay. I still have not hooked it up. I need to one day.
    When I want to reallyyyyyy get loud, i put the 2.3' and the 1.2's on at the same time. OMFG the entire place just rattles like crazy. I have 2 amps and 3 sets of speakers so i was going to put the selector between the amazings and the 2.3 but just never got around to it. I just unplug for now.
    heiney9 Posts: 25,432
    wingzam wrote: »
    Banana Plugs
  • erniejade
    heiney9 wrote: »
    Banana Plugs
    Yes i am running them but, it is still hard moving the 1.2's and the carver amazings out from where they are to get to the plugs.... or the amps...
  • wingzam
    wingzam Posts: 201
    erniejade wrote: »
    Ernie i've heard you mention the "amazings" a couple times...What is an amazing??
  • erniejade
    Sorry about that carver amazing speakers original hard to drive dips down to 1 ohm 2 30" ribbon + 4 12 " free air woofers per cab.
  • wingzam
    wingzam Posts: 201
    Damn Ernie!
    Now me myself?I wouldn't call that wretched excess,but I understand these things..
