Amp recommendations for Monitor 10 ?
Almostablaze
Almostablaze Posts: 4
edited February 2010 in Forum Testing Area
I'm glad to have joined recently and I'd like to thank everyone for their time and input. Past, present, and future.
I'm looking for recommendations for an amplifier to use with my Monitor 10b's. I've got a Yamaha RX-V590 that puts out 80W @ 6ohms and the Polks sound pretty damn good. I'm just thinking I'd like to put a little more power to them. I don't know much about amps. Or if I'll even notice an improvement in what already sounds great. Is this a good idea? Down the road I'd like to pick up and hook up additional pair. Advice and suggestions are greatly appreciated. Thanks, Brian
Post edited by Almostablaze on
  • McLoki
    McLoki Posts: 5,231
    I have an adcom amp with mine and I think it makes for a pretty good combination. (FYI - mine are Monitor 10 series II)
    Michael
  • bevo
    bevo Posts: 306
    You would get more help if you made your thread in the electronics sub forum. I don't know anything about amps so this is all the advice I have.
    Denon 1909, want to upgrade for pre outs
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
    Panasonic plasma 50 inch
    Buttkicker(don't use or need it anymore since getting the Ultra)
    I don't think you can add an amp, does that receiver even have pre-outs?
  • halo71
    halo71 Posts: 4,639
    I have an Onkyo Integra M504 on my 10's. Think it's 165 wpc?!? And it is way more than adequate. So much so I wish they made "governors" for power amps to keep the wifey from possibly blowing the speakers! :p
    --Gary--
  • Polkersince85
    Polkersince85 Posts: 2,883
    For bang for the buck, the older Adcoms, Carver or Harman Kardon amps work well with the M10s. Get 200+ wpc and you may need a preamp.
  • marvda1
    marvda1 Posts: 4,964
    Puritan PSM156
  • kcoc321
    kcoc321 Posts: 1,788
    I have mine on a B&K St-1400 SII and really like it. It is only 150wpc +/- at 6ohm load of the Mon 10's, but it sounds good to me. It is more of a 'warm' sound, and if you like the Yammu sound, then it may not be for you. I prefer the warmer sounding gear.
    Which tweeter does your have?
  • Almostablaze
    First of all thanks for every ones input. To answer a couple questions:
    tonyb, yes my receiver has front, rear, center, and low pass terminals. Which the owner's manual says I can drive those speakers with external power amplifiers. Great question! I had forgotten that they existed and what they were for. I think I bought the receiver maybe 15 years ago, brand new in the box.
    kcoc321, I'm not sure which tweeter I have, except that they are original. I bought them, for $200 a while back, from a friend at work (the original owner). He thinks he bought them some time around 85'. He still owns the Carver amp he used with them. I'd make him an offer for it. But, unless it puts out more than my Yamaha it seems pointless I guess.
    So, I'm grateful to everyone for helping me learn about this stuff:)
