Installing a new driver in a Monitor 60
Underworld54
Polk is sending me a replacement driver for one of my Monitor 60's and I was wondering how much of a chore is it to replace them? Can someone maybe give me some direction on doing this? I really appreciate it, I don't want to screw anything up.
Post edited by Underworld54 on
If you know how to hold a screw driver, in this case mostly it will be a Alan Wrench probably 3.5size, you should be done in 10 minutes max, just be gentle while **** in the new one don't damage the cone or the rubber surround thats the common mistake, tighten the bolts in tandem with other ones, dont tighten one single bolt at a time. Also be gentle while disconnecting the wires at the mid woofer terminals,:p probably it took more time for me to type than it will take you to change the mid wooferUnderworld54 wrote: »Polk is sending me a replacement driver for one of my Monitor 60's and I was wondering how much of a chore is it to replace them? Can someone maybe give me some direction on doing this? I really appreciate it, I don't want to screw anything up. -
jacob.simpson wrote: »If you know how to hold a screw driver, in this case mostly it will be a Alan Wrench probably 3.5size, you should be done in 10 minutes max, just be gentle while **** in the new one don't damage the cone or the rubber surround thats the common mistake, tighten the bolts in tandem with other ones, dont tighten one single bolt at a time. Also be gentle while disconnecting the wires at the mid woofer terminals,:p probably it took more time for me to type than it will take you to change the mid woofer
Agreed - it's very straight forward.
Get all the screws started so the driver is properly aligned - don't overtighten.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
Agreed, you should have no problems at all. Fairly straight forward. Good luck.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Thanks guys, I was hoping it was going to be pretty straight forward. I'll let you know if I run into any issues. Thanks again.
I just received an e-mail from Kim from Polk and it sounds like she is sending me a complete set of drivers for the speaker even though only one is shot. How do I know which is which when I go to replace the faulty one? I'm only going to replace the faulty one and save whatever else I get for future use if need be. If it helps guys there are 3 drivers in the Monitor 60's and it's the bottom one that is faulty.
They should all be the same driver? They are all "5-1/4" Diameter Dynamic Balance Bi-laminate composite cone driver, magnetically shielded." Direct from Polk's product page. Someone with more knowledge should be able to confirm/deny this claim on my part.
-JeffHT Rig
Blu-Ray- 80 GB PS3
wutadumsn23 wrote: »They should all be the same driver? They are all "5-1/4" Diameter Dynamic Balance Bi-laminate composite cone driver, magnetically shielded." Direct from Polk's product page. Someone with more knowledge should be able to confirm/deny this claim on my part.
-Jeff
Isn't there 2 drivers and 1 tweeter? -
Monitor 60's should have 3 Mid/Woofers and 1 Tweeter. The tweeter is the small silver colored one in between the top two drivers.
http://www.polkaudio.com/homeaudio/specs/recent/monitor60/ spec page
-JeffHT Rig
Blu-Ray- 80 GB PS3
Underworld54 wrote: »Isn't there 2 drivers and 1 tweeter?
Yeah.
Put the tweeter in the small hole. Put the midranges in the big holes.
(3 of them) I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Would I be ok just to change the driver that is faulty and save the other for future use or should I go ahead and change everything?
Sure.
I'd PERSONALLY replace them all, then keep your old good driver as a spare, but either way works.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
You are gonna do it for him concealer? LOL
I am with him on this one though, keep that other as a spare, gonna change one may as well change em all.
-JeffHT Rig
Blu-Ray- 80 GB PS3
If he's close and wants to bring it to me, sure. I'm all for some easy work and a visit.
LOL, damn. So much for my sarcasm.
-JeffHT Rig
Blu-Ray- 80 GB PS3
Oh, i got it.
Just playin' along i guess. It's too early for REAL joking. I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »Oh, i got it.
Good call, lol.
-JeffHT Rig
Blu-Ray- 80 GB PS3
Ok guys, I got my driver set today from Polk and I received 2 drivers with black cones and 1 with a silver cone. Which of these go where? I'm going to take all your advice and replace all of them in that on Monitor 60.
Black cones (larger ones) should be the woofers, and the silver cone (smaller one) is the tweeter. Just pop the grille off the other speaker and use it as a reference. Good luck, hope you get it done.
-JeffHT Rig
Blu-Ray- 80 GB PS3
BTW, Kim is a guy..
Just take the grills off and replace the drivers one at a time, matching the one you took out to the one you're about to put in. Its really simple. Like the others said, be careful with your tools so you don't slip and puncture anything. Also, make sure you don't overtighten the screws when you put them back in, they will strip easily and pull right out of the MDF. Good luck,
DominicHome TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables -
Ok i'm going to be doing the new install later tonight and I had one last question. Should I lay the speaker doen on it's back to change out the drivers or leave it standing up? Thanks guys.
Better to make them lie flat, make sure you remove the Banana or Speaker wire connections from the rear, Treat them like changing for a new Born baby:p
Dont get tensed, thats the key, handle the tool with utmost care with regards to the new drivers let us know once you are done. -
jacob.simpson wrote: »Better to make them lie flat, make sure you remove the Banana or Speaker wire connections from the rear, Treat them like changing for a new Born baby:p
You mean just undo the wire right? not actually take apart the terminals. -
yes just disconnect them.
Thanks, hope all goes well.
Good luck man, trust me you are overthinking this. Easy peasy, lol. I would be the same way though, gotta make sure you do it right, yanno?
-JeffHT Rig
Blu-Ray- 80 GB PS3
I feel for ya UW, when I re-foamed my Advents I felt like I was performing some type of surgery.
Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
Can someone please tell me what the secret is to get the clips seperated? They should slide out and they aren't. Also all the drivers are silver and they sent me ones that are black so if I change out all 3 then my speaker will not match my other one if I choose to run them with my grills off.
I just pulled the wire off one of the clips....now what? Grrrrrr.
