What are the most accurate studio monitors i can get for like a thousand bucks?
Curtis Day
Curtis Day Posts: 23
edited February 2010 in Speakers
Any ideas? Powering with a monster 2250.
Post edited by Curtis Day on
  • nguyendot
    nguyendot Posts: 3,594
    I use Boston Acoustics VR-M60s
    Main Surround -
  • TNRabbit
    TNRabbit Posts: 2,168
    JBL 4312 Studio Monitors
    for $1k you can get FOUR of them~
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
    tonyb Posts: 33,068
    Sure you want accurate ? Your source better be up to snuff otherwise bad recordings will become even worse.
  • Matt34
    Matt34 Posts: 318
    What are they going to be used for? Audio mixing and mastering or just near field playback?
    mhardy6647 Posts: 34,938
    You could probably get a pair of Altec 604-series duplex drivers for a kilobuck, but the crossovers and cabinets would put you over budget. These were the sine qua non
    for decades (and still tough to beat, if you ask me). The UREI monitors (at least some of 'em) were essentially 604s with subwoofers added.
    http://www.lansingheritage.org/images/altec/specs/home-systems/891a-897a/page3.jpg
    New production available from Great Plains Audio but a little pricey.
    Maybe you can luck into a pair of BBC LS-3/5A-specification nearfield monitors for that (but probably not).
    Otherwise, I think you're looking at inaccurate studio monitors for that sort of money (sad but true).
  • Face
    Face Posts: 14,340
    Tannoy.
  • steveinaz
    steveinaz Posts: 19,545
    ACI Emeralds might warrant a look.
    Face wrote: »
    Tannoy.
    mmm. Distinct possibility. I tend to forget about Tannoy (but I shouldn't).
  • zingo
    zingo Posts: 11,258
    If you truly are looking for accurate monitors, I would get powered monitors. The speakers and amps are better matched and you have less components to worry about; there is a reason they are made.
    You can't go wrong with Mackie or Genelec. I've also heard nothing bad about Focal monitors if you can get them used, or the CMS 50 model.
  • dorokusai
    dorokusai Posts: 25,576
    Tannoy pops into my head only because of the aforementioned posts...always neglect them mentally. I really like concentric designs for accuracy and KEF would be a cheaper alternative and I'd go vintage as well.
    I wouldn't choose a Mackie or Genelec if my life depended on it.
  • curved
    curved Posts: 664
    TNRabbit wrote: »
    I do like mine (will be replacing caps and resistors as they are starting to fade)....although Tannoy or Dynaudio come to mind.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
    I have heard really wonderful things about the Genelec monitors (but I have never seen nor heard them myself, nor have I priced them). Worth consideration by reputation.
  • concealer404
    concealer404 Posts: 7,440
    Face wrote: »
    Tannoy.
    2nded.
  • john22614
    john22614 Posts: 214
    B&W 805's used is you can find them
    B&W 804s mains
    B&W HTM4 center
    Polk PSW 1000 sub
    Outlaw 990 Pre Amp
    Anthem MCA 30 Amp
    Monitor Radius 180 surrounds
    Audiosource Stereo Amp for surrounds
    Denon 2910 Universal DVD/SACD Player
    Comcast DVR
    Pioneer Elite 42" Plasma 940 HD
    Harmony Universal Remote
    Blue Jeans interconnects and biwires
    Itunes Air Express
  • unc2701
    unc2701 Posts: 3,587
    zingo wrote: »
    Focal, yes- haven't heard any in the price range given, but the ones I have heard are among the best.
    Genelec is CRAP. They might be the worst speakers I've ever heard. AVOID
    Backburner:Krell KAV-300i
    unc2701 wrote: »
    Interesting. As I say, I've no ears-on experience, but some folks whose ears I trust have been effusive about them. Can you elaborate on what makes them so bad? I am really (albeit academically) curious?
    "Accurate" monitors shouldn't be too polarizing in opinion (should they)?
  • ben62670
    ben62670 Posts: 15,969
    Get a better amp, and some Polk monitor7's. Mod the 7's, and use the left over money to get a decent little tubed pre.
    Ben
  • jz0h4d
    jz0h4d Posts: 33
    I just finished a studio project at a studio that was using Genelec monitors. They sounded great.
    ben62670 wrote: »
    (FWIW) I have no idea what a monster 2250 is...
    The Monitor 7 does a credible imitation of the "classic Britsh (mini) monitor sound" indeed (at a bargain price, then and now). I cannot actually imagine they've seen much use as studio monitors, though.
  • unc2701
    Bright. Ear bleeding bright. Worse than klipsch bright. Take an EQ to it and it's still bright. And the bass was as sloppy as it gets. I'll find the model numbers in question, but they were terrible.
    I think Genelec is one of those companies that have the advertising down, but not the research (think Bose). Hell, I've heard rap songs that give shout-outs to their Genelec's. 'nough said.
  • ben62670
    too nearfield can make them blurry so it depends on setup. Monitor is a loose term.
    Ben
    Ben
    "Monitor" (as a noun, describing speakers) is a term that is used loosely. I don't think it is a loose term, though. I thnk that any recording engineer will know exactly what a monitor is (and isn't).
  • MANSKITO
    MANSKITO Posts: 295
    http://www.paradigm.com/en/reference/fronts-studio-studio20-model-2-13-1-26.paradigm
    Paradigm Studio 20s easy the best I have heard at that price point, I hate to say it but they were better then the LSI 9s.
    But I just heard them my mind might change when I go back to hear them again and I have time to think about it. I usually get overly excited when I hear new speakers for the first time.
    Monitor 60s, CS10 front
    Monitor 40s, back
    PSW10:(
    H/k AVR 325
    Sansui Tape Deck
    Pioneer PD-5010 CD player
    Sennheiser HD 650s :D
    Maverick Audio Tube Magic D1 DAC
    AMD Phenom II 940 @ 3.8 prime stabel
    4 gigs 1066, cas 5
    XFX 4890 1gig
    Seagate 1tb 7200.12
    Creative X-fI Titanium Fatal1ty
  • MANSKITO
    MANSKITO Posts: 295
    MANSKITO wrote: »
    Heres a review of them, Thinking back to the demo I had with them I rather agree with its conclusions.
    http://www.stereophile.com/budgetcomponents/508para/index1.html
    Monitor 40s, back
    PSW10:(
    H/k AVR 325
    Sansui Tape Deck
    4 gigs 1066, cas 5
    XFX 4890 1gig
    Seagate 1tb 7200.12
    Those Paradigms are an 8 ohm load, the LSIs a 4 ohm...the question? Were the LSis properly amplified because without GREAT power they will NOT sound very good but will sound flat and lifeless? I have not heard the Paradigms but I have my doubts about them beating out LSI-9s for musical reproduction. But, as I said, I need to hear them.
    cnh
  • lightman1
    lightman1 Posts: 10,796
    I have a pair of Paradigm studio monitors. They REALLY come alive with the proper amp and source. I'm diggin' the 'digm!
  • MANSKITO
    MANSKITO Posts: 295
    cnh wrote: »
    cnh
    It could be the gear, gear was different I can't rule that out but all things considered both Speakers were powered by a a lot of sweet looking gear.
    Don't get me wrong the LSI 9s where not put to shame by the studio 20s in terms of SQ, it was not a completely one sided battle but still the 20s where the better speaker in sound and better build quality.
    While the LSi9s where better in a few areas, the delta between the studio 20s and the LSI9s was large enough to where I don't think any one if they heard both speakers would disagree with my judgement.
    How ever now that I think about it, The LSI9s where demoed as speakers for the audiophile on a budget and the gear probably reflected that. While I know I have a good ear for sound, I do not yet have an eye for good gear. So I can't even begin to say if the gear was on the same level as the Paradigm speakers. They where actually the lowest end speaker he carried. Still though I don't think they where under powered they sounded fantastic just not as good as the Paradigms.
    While the dealer that carried the Paradigm studio/Signature speakers billed them as something closer to the best speakers you could buy for any reasonable amount of money. And again if I had to guess the gear probably reflected that as well.
    So again I say it could very well of been the gear that made the difference in sound. But the gear Had nothing to do with the respective build quality of the speakers, and let me tell you the Paradigms where SEXY as hell. But they where not so sexy that i would buy them over the LSI9s if in fact the gear was the reason the Paradigms preformed better.
    But by all means go listen to the paradigms if you get a chance there now up there as some of my favorite speakers that i might one day own.(also please keep in mind that the Studio 20s coast a little over $100 more per speaker and came in just above 1k while the LSI 9s where just under 1k.)
    Monitor 40s, back
    PSW10:(
    H/k AVR 325
    Sansui Tape Deck
    4 gigs 1066, cas 5
    XFX 4890 1gig
    Seagate 1tb 7200.12
  • mopar paul
    mopar paul Posts: 277
    Agreed-If you can listen to the Paradigms Studios I would say do so-I had a pair 2 years ago and they are quite a speaker!
  • Menasor
    Menasor Posts: 283
    Paradigm Studio 20's are good speakers, but I'm willing to bet the Ascend Sierra-1's are better. The Sierra-1's have been compared to Paradigm's Signature line
    http://www.ascendacoustics.com/pages/products/speakers/SRM1/srm1.html
    Great highs, completely transparent mids, and excellent bass extension in a mini monitor. These things can be run at full range!
    Fronts: Energy RC-70
    Center: Energy RC-LCR
    Surrounds: Energy Veritas 1.0CM
    Subwoofer: SVS PC12-NSD
    Receiver: Onkyo TX-SR705
    Amplifier: Denon POA-2200 w/ Ben's ICs
    Pics of my setup (click me)
  • MANSKITO
    MANSKITO Posts: 295
    Menasor wrote: »
    Ya maybe they have been compared to paradigms signature line, but I wouldn't. They may very well sound the part but they certainly don't look the part.
    But i have never heard them, so i can't say.
    Monitor 40s, back
    PSW10:(
    H/k AVR 325
    Sansui Tape Deck
    4 gigs 1066, cas 5
    XFX 4890 1gig
    Seagate 1tb 7200.12
