received new dsotm lp!
madmax
I received the new Dark Side of the Moon LP from Acoustic Sounds last week! I'll comment about it as soon as I get a chance to really listen to it. Unfortunatley my system is being moved around right now for some interior changes. I've been waiting for it for months (I ordered it pre-release) and wouldn't you know I would get it as soon as I started moving things!
madmax
madmax
Vinyl, the final frontier...
Post edited by madmax on
Chuck,
would be interesting to compare the LP with SACD. I was debating about getting the lp and decidedto wait a bit.Do you have the SACD version?I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
Right on, I'm waiting on a turntable to come in from ebay. I got the DSOTM LP last friday. I may have to wait to play it, we'll how the turntable turns out.
Derick.SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop. -
I have the sacd version as well. I've only listened to it in 2 channel though. I want to compare it directly, you know, both sources running at the same time at the same volume and switch back and forth. Too bad the older common version I have sounds like static city. One of my friends has an original master mfsl recording that he says I can compare it to. Should be interesting.
A sealed MSFL DSOTM just went on ebay for $179... I should never have opened the 30 or so MSFL's I bought for $3 a piece when a local record store was swapping to CD's moons ago.
Didn't have DSOTM, but a few other choice ones were in the mix, e.g., Sticky Fingers.More later,
Tour...
Vox Copuli
Oooo.. Sticky Fingers, that's a good one..
What's MSFL???SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
DOH! :eek: finger dyslexic MFSL...More later,
Tour...
Vox Copuli
MFSL
Serious, what's MFSL??? Didn't mean to correct you there, that was just a coincidence...
Edit: damn speller...SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
I typed it in wrong the first time. Took me a few minutes to remember what it was called... Mobile Fidelity Sound Labs I think.
Madmax,
You are correct sir!
MFSL made their name by releasing half-speed mastered, limited pressing LP's on heavy virgin vinyl strictly from the original master tapes.
After the CD explosion they moved on to a gold line of CD's that are very well respected.More later,
Tour...
Vox Copuli
Cool.SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
