SurroundBar 360 and DirecTV remote code
bevcraw
I just connected up my SurroundBar 360 today and the process was pretty painless, especially after using advice I found on this forum. Thanks for advice on best connections for DirecTV. The sound is fantastic.
I programmed my TV to the Polk remote with no problems, but I have been unable to find the right code for my DirecTV H21 HD receiver. I tried all the codes on the on-screen setup and all of the codes in the manual, but I can't get any to work for me. I searched the forum and I found that someone else posted about a similar problem with another DirecTV receiver, without any solution so far.
I would appreciate any advice on the proper DirecTV remote code. Thanks for your help.
Post edited by bevcraw on
May be an issue for DirecTV CS, but maybe somebody else has the solution for you. If you don't get any answers in a few days, I would call them and see if they have a solution for you. Good luck and welcome to Club Polk.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Thanks for the response. My past experience is the DirecTV customer service has not been helpful on this issue.
Yeah, I had DirecTv for awhile and I noticed they weren't that helpful either. That was the only advice I had on the issue, hopefully someone else can help.
-JeffHT Rig
Blu-Ray- 80 GB PS3
