Emotiva XPA 3 ?
motobman
What does everyone think of the Emotiva line ? Seems hard to find an EMOTIVA XPA 2 but what about the Emotiva XPA 3 ? Are the specs ok and would that help my A9 fronts ???
Thank you,
-Moto
Thank you,
-Moto
I run my a9s off an xpa-3. made a huge difference in sq even at lower volumes. much more detailed. what are using for a center?panasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one -
Right now it is a large, Proficient Audio and I don't think it is rated very high. I plan to upgrade to a CSI A4 or A6.
As if we didn't have enough emo threads. The search function is your friend and specs mean nothing.
go with the a6 if you got the spacepanasonic th-50pz85u
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one -
Say I bought a Emotiva XPA 5 (5 channel amp), simply for my front RTI A9's and center speaker. Could you, or "Would" you bi wire the A9's like I am doing presently off of my Yamaha RX-V1900 ? If I get an XPA 5, should I bridge the speaker posts, or bi-wire them and run one channel to each of the speaker's posts (using four of the five amp outputs). Thanks again, you guys are a real help,
-Moto -
Good "bang for buck" product's, work extremely well with Polk's.
My a9's sounded good running off my AVR (same as your's), sounded better when i added an xpa5, and sound even much better since adding a pair of xpa1's!
a6 for center duty is the way to go IMHO, match's beautifully with the a9's.
xpa5 for the front soundstage would be interesting. Use 4ch's for the a9's and the final ch for the a6
I would say that it would sound good, most likely better than the xpa3 alone. Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
If you want the best solution for 2ch then the xpa1's are the way to go.
Glad i picked mine up
If you want to maximize a rig's potential for music/HT then go with a multi channel amp, xpa5 for the front 3 as i mentioned in my earlier post should be more than adequate. IIRC the xpa5 has more capacity and a larger transformer as compared to the xpa3....Media Room 7.1
HTPC
Didn't try it as it didn't interest me because i knew i was getting mono block's
The xpa5 would be better than the xpa3 IMHO, but best for 2ch is xpa1's or xpa2 it's the way to go :cool:Media Room 7.1
HTPC
-Moto
I had my LSi-15's and the XPA-5 wired in a Bi-amp (seperate channel for each set of binding posts) configuration, There was only a very slight difference in the low end, I don't think it's worth the extra wire.
Jimmy -
Use the search function your questions have been answered atleast a 1/2 doz times.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
To the O/P you should not base opinion's solely on paper spec's of ANY product, regardless of the manufacturer :cool: IMHO Emotiva provide's an option to many people who want better performance than integrated component's offer without "breaking the bank" and also give's many the piece of mind you get with NEW component's as opposed to the uncertainty of used item's. They definately are NOT the be all, end all but definately a quality product for the price
The O/P's question's are valid, there is NO need to "police" the forum and discourage new member's from posting
I will agree with you that yes one can obtain much information from doing a search but if everyone only used the search we would have no "traffic" on the forum and it would stagnate.
If you feel the need to "police" maybe you can get a grip on all of the spam post's and all of the ignorant flaming and useless post's that go on here by a few member's simply for the sake of upping their post count
Media Room 7.1
HTPC
I'll reiterate,
USE THE SEARCH FUNCTION the questions have been answered many, many times.
Can you use a larger font and brighter colour? It's kinda hard to read :rolleyes:Media Room 7.1
HTPC
I'll reiterate,
The man has a point. Nobody is trying to discourage people from posting, just teaching them how to use the forum to best answer their questions. Nothing more, nothing less. It may rub some the wrong way when the same questions are asked every day,over and over again. Learn how to use the forum, specifically the search feature, first,before posting repeat questions.HT SYSTEM-
lsi 9's -
If that is the case then 99% of the post's on this forum would not be here, there is a thing called Google that can answer ANY question anyone has. He has some deep seeded issues that he is refusing to acknowledge so he act's out against other's to feel better. I pitty him
Media Room 7.1
HTPC
sTiLlLeArNiNg wrote: »If that is the case then 99% of the post's on this forum would not be here, there is a thing called Google that can answer ANY question anyone has. He has some deep seeded issues that he is refusing to acknowledge so he act's out against other's to feel better. I pitty him
Really ? Google ?
If that were true, then why are you here ? I mean, if Google can answer all your questions, all these audio clubs should just go away then.
The poster you question is well respected around these parts. He, myself, and others may get testy from time to time at the lack of newbs to learn how to use a forum,ask a question, or use manners. You may have a personal issue with Heiney, none of my buisness, and even though this is an internet forum, a tad bit of respect goes along way.HT SYSTEM-
lsi 9's -
This is the age-old thing with internet forums...happens on every one I've been on. Long standing members who get tired of seeing the same stuff repeated versus noobs looking for info.
Why not let these guys have their thread? Easy enough to skip over it if you've BTDT.SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub -
Jetmaker737 wrote: »This is the age-old thing with internet forums...happens on every one I've been on. Long standing members who get tired of seeing the same stuff repeated versus noobs looking for info.
Not exactly, more like noobs being too lazy to search and have everyone else do their leg work for them. They can have their threads, nobody says otherwise, just when it gets repeated over and over, they will be called on it to search for the answer as it has been talked about a million times over. Much like cable debates.HT SYSTEM-
lsi 9's -
In the time it took you to log on, reply to this post 2 times, change your font size and color, you could have just put links to the answer using the search function.
Not trying to jack the thread, sorry about this. I agree with trying to use the search function but compared to other forums this one seems really picky. On another note it is also nice to have information brought up again every once in a while, if you don't want to post about it then you don't have to, just skip over it.Denon 4310
(2)Emotiva XPA-2
(2)Polk RTiA9, Polk CSiA6, (2)Polk DSW660, (4) Polk OWM3
Panamax M5400-PM
Samsung 50" Plasma
XBox One w/external HD, AppleTV, Samsung Blu Ray -
Blah, Blah, Blah, Blah, Blah, Blah, Blah, Blah, Blah.......did I mention Blah?
Hey i want another post too, so blah!
YAY! My e-peen is bigger now
Media Room 7.1
HTPC
Makes sense, and sorry, just a new Polk owner and a new poster as well.....
I remember when my frien Sean in high school raved about Polks........I always wanted a pair.. Now I have fronts and a sub, and just want the right amp, amps to run them.
Thanks guys,
-Moto -
Are there a lot of Emo threads here? Yes. Could someone use the search function? Yes. Perhaps folks asking these redundant questions are just wanting to chat audio? If everybody used the search, where would all these "spirited" discussions happen?
I think if a guy who is obviously new here posts a repeated question he's looking for info and way to stimulate some discussion and really doesn't deserve to be blasted right off the bat.
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
We dont want another cyber Emo fight..Marantz 1607 - Polk S60 - S35 - Emotiva XPA-3 - Polk DSWPRO550wi
Gordon
Who blasted the OP? When I recommend the search function it is because there is plenty of info on the subject already:cool:Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Yeah,from a year ago.HT SYSTEM-
lsi 9's -
Your elevator never leaves the ground floor, does it?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Oops I quoted from over a year ago. So many of these damn EMO threads I thought I was posting in the other one. No not that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, or that one, but the other one:biggrin:Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Maybe someone should post a "sticky" thread regarding Emotiva Amps entitled, "So you're thinking about buying an Emotiva amp? Read this first before posting." Just a thought......LIVING ROOM:Pioneer PDP-6070HD, Pioneer Elite SC-25, Pioneer Elite BDP-05FD,
Emotiva XPA-5, Emotiva USP-1, Polk LSI15's, Polk LSiC, Velodyne 12", Mirage Nanosat Prestige rears, MIT AVT Speaker Cables, Audioquest King Cobra Interconnects, Panamax M5300pm Surge Protection/ Power ConditioningBEDROOM: VIZIO 32" LCD, Pioneer Elite VSX-23txh, Pioneer Elite BDP-23FD, Parasound HCA-2205A, Mirage Nanosat Prestige Speakers 5.1, Mirage S8 Sub, Monoprice cables, APC Surge Protection. -
No.."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
