newby question
ednem
I just bought HK AVR525 - open box. But by mistake they gave me wrong remote from AVR 120. I just find this out. May I still do setup all my system with this remote? Any advise?
Post edited by ednem on
You should be able to access all of the features with that remote, but it wouldn't hurt to go back and get the correct remote.
Most brands use the same IR codes.The only thing you will loose in the model IR codes that only work for your unit.Like features/surround modes etc.Go back and get the correct remote......or to hell with it and get yourself a Pronto...Dan
wrong remote doesn't have OSP button and I can't access this option from aplifier. By the way/ what is Pronto?
Philips Pronto.It's a universal remote control,actually a family of remote controls now that are touch screens and can control anything IR....
go here...
www.remotecentral.comDan
