Antivirus / Office for Ubuntu?
Serendipity
Serendipity Posts: 6,975
edited January 2010 in The Clubhouse
So - I'm new to Ubuntu and installed it on my DIY PC over Windows XP.
What antivirus software should I install before I start browsing the web?
And how come I cannot install Microsoft Office on Ubuntu?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • KrazyMofo24
    KrazyMofo24 Posts: 1,210
    edited January 2010
    One of the benefits of using Ubuntu is not worrying about an antivirus. You can use openoffice, Microsoft does not want/allow Office to work on ubuntu/linux.
    Setup:
    2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
    PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
  • Serendipity
    edited January 2010
    How then would I open .docx files that people send me?
    When I save in OpenOffice I can choose from .odf or .doc but what about opening files?
  • KrazyMofo24
    edited January 2010
    .docx is for Office 2007 and newer. Even office 2003 doesn't open those unless you get a converter for it. I would make sure it's newest version of OpenOffice, or search the ubuntu forums I'm sure they'll have some info on it.
    Setup:
    mhardy6647 Posts: 34,940
    edited January 2010
    Interoperability between OpenOffice and at least earlier versions (though at least '03) of **** is pretty good.
  • Serendipity
    edited January 2010
    Yes, I can read a .doc (Office 2003) file perfectly, but when someone sends me an Office 2007 file in .docx file format I cannot open it properly.
  • Serendipity
    edited January 2010
    Anything with graphs/charts/complex formatting looks strange in OpenOffice. Not sure if it's a user issue, or something I need to tweak in OpenOffice.
  • Sami
    Sami Posts: 4,634
    edited January 2010
    Make sure you have at least OpenOffice 3.0 or newer. If it isn't installed by default by your distros repository, you will need to use an alternative repository. Which version of Ubuntu you have? 9.10?
    Some links you might find useful:
    http://www.oooninja.com/2008/12/better-office-docx-converter.html
    http://www.oooninja.com/2008/01/convert-openxml-docx-etc-in-linux-using.html
    http://news.softpedia.com/news/How-to-Install-OpenOffice-org-3-1-on-Ubuntu-9-04-111105.shtml
    Like said earlier, no antivirus is needed, just make sure your firewall is setup. If you feel the need to have AV, install ClamAV. It should be available in the software installation menu.
  • Serendipity
    edited January 2010
    Sami,
    I am using Ubuntu 8.04 and Knoppix 3.0 (these were CDs someone gave me). Both come with older versions of Openoffice. I think I need to install OpenOffice 3.0 on the Ubuntu in order to get this to work.
  • packetjones
    packetjones Posts: 1,059
    edited January 2010
    you may also try to install Microsoft office via wine.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • Serendipity
    edited January 2010
    And it will run Office fully with no compatibility issues?
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited January 2010
    It should, I've run it successfully. I run Ubuntu on my main machine now and keep a virtual machine of Windows for things I don't have time to play with. Using a software like VMWare Workstation's Unity makes it pretty seamless.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2010
    I love Ubuntu/Linux as well. MS programs will not work on Ubuntu (for the most part without wine or something to that effect as mentioned) I have the same problem with my Zune software, that is the only reason I still run Windows on a seperate partition and dual boot.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Sami
    Sami Posts: 4,634
    edited January 2010
    Sami,
    Are you using the LiveCD or have you installed Ubuntu? If you have installed, you can do a distro upgrade. Unless there is a specific reason why you're staying with 8.04, I would recommend the upgrade.
    http://www.ubuntu.com/getubuntu/upgrading
  • Serendipity
    edited January 2010
    Sami wrote: »
    Both. Knoppix as a LiveCD (run off the CD-ROM drive), and Ubuntu installed on the hard disk.
  • John30_30
    John30_30 Posts: 1,024
    edited January 2010
    Keep in mind that the compatibility between Microsoft Office and Open Office is one-way, there are issues going back to MS Office.
    Iow, you can open and modify Office 2003 documents in Open Office, but don't expect to be able to then use MS Office on them or docs created in Open Office under linux.
  • Serendipity
    edited January 2010
    John30_30 wrote: »
    That's the issue I am having. Complex formatting looks funny/skewed when you open and modify Office 2003 documents in OpenOffice, and even more strange when you use MS Office to read an OpenOffice document.
  • Serendipity
    edited January 2010
    I take it then you must install Microsoft Office in order to keep the formatting of documents intact? I hate having to re-edit documents because conversion from Office 2007 to OpenOffice to Office 2003 messes up the formatting.
    How do I take care of this?
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited January 2010
    What he said
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • John30_30
    edited January 2010
    Get a freeware VMware server for linux, or use Wine and run XP and Office 2007 through that. It's a PITA, but it's the nature of the beast.
    Google docs online might do it also, which would totally solve it for you.... I can't recall if the formatting stays good. It probably is a OpenOffice free version also, so probably will not help.
    I was messing with a doc for my daughter in it some months back.
  • Serendipity
    edited January 2010
    What he said
    Doesn't solve the issue with .docx files.
    I guess I will have to install Office 2007 with WINE, but I was hoping to not have to do so.
  • bigaudiofanatic
    edited January 2010
    True I am wondering if the mac version of office would work with ubuntu. I never tried I just use my mac. :p LOL
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Sami
    Sami Posts: 4,634
    edited January 2010
    Upgrade your OO to 3.0 and you will get docx support.
    http://www.howtoforge.com/how-to-install-openoffice-3.0.0-on-ubuntu-8.04
  • Serendipity
    edited January 2010
    Sami wrote: »
    Yes, I did that. Compatibility is possible but the converted files are far from perfect. Graphs, tables, and charts sometimes get messed up.
  • Face
    Face Posts: 14,340
    edited January 2010
    I love threads like this.
  • Serendipity
    edited January 2010
    Ah well, based on reviews of WINE I am going to just install XP and dual-boot with Linux.
  • John30_30
    edited January 2010
    For the OP's sake, NO it will not install under linux.
    But you go ahead and try since you thought of it.
  • bigaudiofanatic
    edited January 2010
    John30_30 wrote: »
    I was just thinking I have a copy of ubuntu but never really used it that much. Just trying to think outside the box. I will ask my teacher tomorrow about other programs he can use. Considering the class is on linux install and operations.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • John30_30
    edited January 2010
    It's too bad you have to have 2007 compatibility, because I just tried it using Google docs, and it saves in Word 2003 format with no apparent problem.
    Which would be way sweeter if someone got on Google's **** to give it 2007 compatibility also. Another cool thing is they will save as a pdf. Just can't go back to Word 2007 and work on them. :(
  • Sami
    Sami Posts: 4,634
    edited January 2010
    Better option would be to install VirtualBox and boot that up whenever you need Office. Another option is to use ODF instead of DOC/DOCX but I don't know if that works any better.
  • rayslifecycle
    rayslifecycle Posts: 511
    edited January 2010
    This doesn't solve your immediate problem - but I installed open office on my machine at work as well as my Windows PC at home - they have a windows compatible version - and that is all I use - Microsoft gets no play here.
    Other programs to look into are "Gimp" - which I am using now instead of photoshop - and inkscape - which I am using instead of adobe illustrator - if anyone wants really good image editing and page layout software - these are quickly becoming a close second to the adobe creative suite.
    Good luck - there is nothing more enjoyable then a computer that works well.
