psw 550 not working
dscottjr550
dscottjr550 Posts: 3
edited January 2010 in Troubleshooting
My psw550 sub has no sound. I have eliminated the signal source as the problem. When I use a test tone from the receiver, I can hear it in the sub, but barely. Something tells me that the amp inside the sub is malfunctioning. Any ideas?? Is this a repairable item or do I need a whole new sub?
Post edited by dscottjr550 on
  • dscottjr550
    edited January 2010
    The model number on the back says it is a psw-550, not 505. I bought it new back in 2001 and it worked fine for several years, but hasn't worked for the last couple of years. I have tried changing the configuration on the receiver (ie large, small, etc) but it doesn't change anything. I then thought maybe the pre amp output went bad. Just bought a new receiver yesterday, but the sub still won't work. Connected via the LFE.
  • dscottjr550
    edited January 2010
    I have tried all 3 inputs. The power 'on' light is coming on and the fuse inside seems to be intact, but still no sound. Guess I will have to contact customer service. Do you know if the internal amp is a user-serviceable part that I can replace myself?
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2010
    xcapri79 wrote: »
    Otherwise you can call Polk customer service and they will advise you what to do.
    +1, Polk CS will take care of you.
    Give them a ring, and they will have you back up and running in no time. Welcome to Club Polk.
    1-800-377-POLK (7655)
    9AM-5:30PM EST Mon-Fri
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Raven47326
    Raven47326 Posts: 4
    edited January 2010
    No sound out of PSW505. Hooked cd player into back of sub (suggested by Polk Tech Support) and only slight static heard when sub turned to max volume setting. Out of warranty 8 months (bought 05/04/2006) has not worked in 3 or 4 months. I saw other people helped without sending sub in hope someone can help me, work cut hours last year 20%. Back to full time now but catching up. Can I check volts or Ohms to try and determine anything.
    Thanks, Brian
