Just bought Elite AVR VSX23...
Jdubbs
Jdubbs Posts: 51
anyone out there have any tips for getting this hooked up? you know...the little things you wish you knew before you set yours up lol...thanks.
50" Sony LCD
Denon 3805
Polk Audio RM 20 system
Polk Audio 12" sub
PS3
Wii
Harmony One
HT system #2
55" Samsung LED
Pioneer Elite VSX 23
Fronts, Center- Polk VM 20
Rears- Polk VM10
Sub - DSW Pro 600
Harmony 900
    edited January 2010
    Haven't worked with that unit so no tips here. But if you installed a Denon 3805 in your system whatever the Pioneer has for set-up menus should be a cake-walk for you...!
    cnh
  • mantis
    mantis Posts: 17,689
    edited January 2010
    If your 50 inch LCD is HDMI then wire everything in HDMI that can be.
    Use BD for Blu ray
    HDMI 1 for cable or DSS/SAT
    HDMI 2 for a standard DVD in HDMI
    HDMI 3 for a game system
    Whats nice about Pioneer ELite receivers is the fact the HDMI inputs do not use up the analog inputs like TV or DVD. They are still open for other sources to be connected. You don't have to assign the HDMI inputs to anything. They are there own inputs.
    USe MCACC after you get all speakers and everything connected. Read the manual.
    Dan
  • Serendipity
    Serendipity Posts: 6,975
    edited January 2010
    Connect everything HDMI, as mantis said analog sources don't have to be shared with HDMI inputs.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
