Cd player or Blue-ray for cd
Soundmind
Soundmind Posts: 22
edited January 2010 in 2 Channel Audio
My Sony blue ray seems much warmer than my Sony ES cd player ? Your thoughts ..
Panamax M5100-EX HT Power conditioner
Yamaha RXV861 tuner
Carver TFM25 amp
Carver av-405 surround amp
Carver ct-17 Tuner
Sony BDP-S350 BluRay
Sony 222ES CD
Sony PS-LX520 Linear track Turntable
Panasonic 46" flatscreen
Polk LSI 15 mains
SVS PB-12 plus Sub
JBL center channel
Polk LSI 9 surrounds
Polk monitor 12 series II "old mains"
Post edited by Soundmind on
    edited January 2010
    How do you have it all hooked up? You may have to change audio settings in the blu-ray if spinning cd's.
  • mantis
    mantis Posts: 17,581
    edited January 2010
    I rarely ever use a CD player anymore. I have had my very nice Pioneer ELite 400 Disc setting in it's box for years. Probably like 7 years now. I never even hooked it up since I moved into my new house years ago.
    Using a Blu ray player as a cd player is perfectly fine. If you have it digital out , you will have a hard time hearing any difference at all. If you have analog out for cd , this is where it will make a difference depending on the quality of DAC and analog cables used. I say uninstall the cd player and use the Blu ray Digital. Less gear less mess. Less is more.
    Dan
  • danz1906
    danz1906 Posts: 5,144
    edited January 2010
    mantis wrote: »
    Agreed, If your using the digital out-your using your Blu-ray player
    as a transport. If you are going to use the analog outs, then a Blu-Ray
    player like the new Oppo BDP-83se would be the ticket:)
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
