mon 70
mvs9963
hey guys just got my amp and trying to hook it up. Had my mon 70 bi wired from my marantz for the past couple of weeks to try it out. now when i went to put the stock jumper back on, im only getting lows or highs depending on top or bottom post i use cant figure it out thanks
Post edited by mvs9963 on
hey guys tried running 70s off of the marantz and still the same thing i hope nothing fried
make sure the binding posts are tight on the jumpers. If that still doesn't work, make up some home made jobs real quick with some spare speaker wire. If that doesn't work, chances are your XO is fried. Are you still under warranty? Polk's customer service is amazing, hopefully they can help you, Good luckHome TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
thanks for the help made some new ones out of some 14 ga works great
