PSW404 no output
scotty54
scotty54 Posts: 1
edited January 2010 in Troubleshooting
I am getting no output at all from my PSW404. I have a new blu-ray player and was connecting as an external decoder through my Yamaha surround receiver and noticed no woof. Then I tried the optical connection and selected the DVD/CD input and have same problem. Prior to the blu-ray, I was just running the sub off the leads from my RM6700 system. This was probably a problem prior to the blu-ray as I haven't used my system in a while. I have tried running a direct cable from the DVD's sub out to the LFE input, a direct cable from the receiver's sub out to the LFE, as well as the original RM6700 setup and nothing. Green power light is on. I can't see a fuse holder on the back of the sub, so am not sure where to go from here. How can I test the PSW to ensure it's not just dead? Help appreciated.
Post edited by scotty54 on
  • MANSKITO
    MANSKITO Posts: 295
    edited January 2010
    Try using the speaker level inputs, if that dose not the help contact Polk's support line
    Monitor 60s, CS10 front
    Monitor 40s, back
    PSW10:(
    H/k AVR 325
    Sansui Tape Deck
    Pioneer PD-5010 CD player
    Sennheiser HD 650s :D
    Maverick Audio Tube Magic D1 DAC
    AMD Phenom II 940 @ 3.8 prime stabel
    4 gigs 1066, cas 5
    XFX 4890 1gig
    Seagate 1tb 7200.12
    Creative X-fI Titanium Fatal1ty
    tonyb Posts: 33,000
    edited January 2010
    Do you have the sub turned on in the blu-ray player ? If so, adjust the sub volume all the way up in the player. Crossovers set ?
