speaker jumpers
13»
  • 62caddy
    62caddy Posts: 137
    edited April 2012
    PiG wrote: »
    Yeah, I was very interested in trying this as a no hassle cheap fix to MAYBE get some improved sound but it seems that there are so many variables that when you try to do it "right" its no longer cheap... so I might try it with cheapo plugs or bare wire but then of course, if you don't hear any differences you blame the lack of quality components... bit of a lose lose situation IMO
    Agreed with tonyb, the cost of jumper substitution is negligable. Changing out internal speaker wiring is something completely different.
    Main:
    McIntosh: MC 2155, MC 2125(x2), MR 80, C 32, MQ 101; Snell J7; Polk: RTiA7, RTiA9;
    Pioneer PL-518; A/T 440 MLa; Yamaha CD
    Vintage:
    McIntosh: MX110Z, MC 2505, MC 240, Thorens TD 145; Shure V15III; Altec 14, Boston T1000; Yamaha CDX 393 CD; Yamaha Cass
  • John K.
    John K. Posts: 822
    edited April 2012
    Junior, brass is approximately 70% copper, with other metal alloyed to make it stronger than the copper alone. It's near-ideal for use as the speaker jumpers(and the speaker terminals themselves, which should also be removed if the brass in the jumpers bothers anyone)and that's why speaker manufacturers use it for the jumpers(when present)and the terminals. The higher resistance compared to copper alone is insignificant over the short distance involved and no adverse audible effects can occur. There's no solid evidence to the contrary, and speaker manufacturers would be foolish to sabotage their own product with something inferior which couldn't result in any significant cost saving. Relax and enjoy your fine speakers
    F1nut Posts: 52,036
    edited April 2012
    I've got news for you Johnny, even Polk is using pure copper jumpers on their TOTL speakers just like other high end speaker companies. Ever see brass IC's or speaker cables? Of course not because brass is inferior. End of story.
  • mantis
    mantis Posts: 17,569
    edited April 2012
    Your theory would be incorrect. Polk has a price point to meet as do all other speaker companies. The plates are cheap and plentiful.
    Upgrading the caps and resistors in your speakers will also result in improved sound. Of course, Polk could use the better parts, but you'd pay a lot more for the speakers.
    You got me thinking with this as I have been dealing with this for years.
    Wouldn't it be cool if polk would offer lets say the RTIA7's as a stock model then offer an ELITE model like the RTIA7E which would be hand selected cost no object best this speaker can be with the best parts? I think the engineers at polk could build a excellent RTIA7 model and I bet the cost would maybe go up 1 to 2 hundred bucks. Even the LSIM series could have an Elite model. This way you know internally the speaker is the best it can be.
    Just food for thought.
    Dan
  • Face
    Face Posts: 14,340
    edited April 2012
    mantis wrote: »
    It's called the LSiM series.
    mantis wrote: »
    I bet it would go up a lot more than $100-200.
    You of all people should know better.
  • Face
    Face Posts: 14,340
    edited April 2012
    John K. wrote: »
    The problem is the other 30%, the quality varies brand to brand.
  • 62caddy
    62caddy Posts: 137
    edited April 2012
    I've always assumed the terminal ends are made of the same material composition as the jumpers.
    If this is the case, would it raise any questions regarding the benefits of jumper substitution?
    Main:
    Vintage:
  • Face
    Face Posts: 14,340
    edited April 2012
    Yes, but the difference would be less subtle than if you have copper posts.
  • jemrey81
    jemrey81 Posts: 161
    edited May 2012
    So after reading this thread multiple times, I got bored enough to replace the jumpers on my monitor 70's.
    I went out in the garage to see what types of wire I had laying around and found some 8 awg wire from an old car stereo install (8awg copper strand for power supply to an amp).... I cut some short lengths of that and used it bare (no connectors on the ends).
    What are your thoughts on this type and size of wire? It's not "speaker wire", so I wanted to check with the experts :)
  • mcnarus
    mcnarus Posts: 20
    edited May 2012
    You could use coathangers. Seriously. It wouldn't make a difference. Jumpers are so short the resistance they add is trivial.
    F1nut Posts: 52,036
    edited May 2012
    mcnarus wrote: »
    Wrong....again!
  • ROHfan
    ROHfan Posts: 1,014
    edited May 2012
    Wrong....again!
    Not really.
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
