The vacuum trick?
Pycroft
Pycroft Posts: 1,961
edited December 2009 in Speakers
Good evenign everyone...
I read somewhere about a vacuum trick to unpop a tweeter that has been a bit pushed in. Is this the best way to go about it? I also heard about some tape, and something with a pin. I've never done this before, and it seems my daughter brushed into a speaker in my living room and pushed it in a bit. Can someone give specific directions on how they have done this...talk to me like i'm an imbiscile! (No comments necessary :))
I'm thinking vacuum first, but not sure if the size of the vacuum matters...I have a huge Hoover vacuum...I don't want to damage the speaker in any way, so the safest would be the best for me...
Thanks,
James
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
  • Knucklehead
    Knucklehead Posts: 3,602
    Ive watched someone do this a long time asgo with a Cerwin Vega. They took the vacuum, put a peice of cheesecloth over the nozzle to cut down on the suction and it worked. Not sure if I would have the balls to try it though.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • NJPOLKER
    NJPOLKER Posts: 3,475
    The way I pulled my dented cap out was easy and safer than the vacuum trick. Use a piece of single coated foam tape. Generally foam tape has a high tack adhesive so be careful not to apply too much of the adhesive side to the cap at first. Foam style tape will easily and quickly conform to the dent allowing you to pull the dent easily. If the dent does not pull use a little more of the foam tape surface and if needed let the tape adhere for a minute or so to build adhesion then gently pull the dent.
  • Pycroft
    If I'm going to use tape, what are the possibilities soem of the sticky tack will get permanently stuck to it, and what damage could taht cause?
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • Polkersince85
    Polkersince85 Posts: 2,883
    Pycroft wrote: »
    A lot less than trying to find your dustcap in the vacuum bag.
    Start with masking tape,
  • NJPOLKER
    If you apply it for a short time the adhesive will not transfer. A short time meaning as long as it should take to pull the dent. The foam itself is coated with a primer by the manufacture that allows the adhesive to bond to it far greater than the dust cap you are pulling on thus not allowing the adhesive to transfer.
  • NJPOLKER
    Masking tape may work fine if the cap does not have a severe dent.
    F1nut Posts: 51,999
    Agreed!
  • skrol
    skrol Posts: 3,462
    That is what the cheese cloth is for, to catch all the pieces.
    Actually is the cloth is tensioned properly it may be to hold the pieces in place while the vacuum is applied.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • gtu2004
    gtu2004 Posts: 620
    for an instant i thought you were talking abt THE vacuum trick...to make it bigger...
    Onkyo 805, RtiA5s, Csi5, Rti6s
  • Pycroft
    You could make your tweeter bigger? AWESOME :)
    Tee hee...
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • Midnite Mick
    Midnite Mick Posts: 1,591
    If you are worried about too much adhesion you could try painters tape.
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • Ern Dog
    Ern Dog Posts: 2,237
    One of my tweeters got pushed in during shipping and to get it out I used the cardboard from an empty paper towel role. I placed one end on top of the tweeter and used my lungs to suck the air and it solved the problem.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    LOL, that's funny right there. True, but funny. :D
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • jax3822
    jax3822 Posts: 88
    I have used the vacuum trick many times and it has always been successful. I have pulled Jbl titanium coated tweeters, Ads dome tweeters (the sticky Ones), and many dustcaps. The only time if failed was to pull out a pair of Jbl titanium tweeters that were crushed pretty good. I have a professional carpet cleaning business and have some pretty powerful vacs. I was tempted to hook the Jbl titanium tweeter to my truckmount vacuum powered by a 25 horsepower Kohler engine running a roots 56 blower, but didnt have the cajones to risk it.
  • nguyendot
    nguyendot Posts: 3,594
    I use that silver ducting tape (aluminum?). Works very well.
    Main Surround -
  • everpress
    everpress Posts: 862
    I um... used my mouth. My vacuum scared the **** out of me... I don't have enough money to pay for a replacement driver over losing a dustcap to a vacuum... So I sucked the dustcap out with my mouth...
    A 20 year old dustcap, by-the-way, taste a bit like rotten ****$ sprinkled in dirt.
    But it worked... You just have to have lungs like a mo-fo....
    ? Harmon Kardon AVR 55 (dead; replacing with Onkyo TX NR-616)
    ? Polk RTA 11TL's (FR and FL)
    ? Polk TSi200's (RR and RL)
    ? Polk CS10 (Center)
    ? Polk PSW-350
    ? Grado SR-60i Headphones
    ? Fii0 E5 headphone amp
    ? iPod touch (8 gig)
    ? iPod Classic (80 gig)
    ? Mac Mini (as media server)
    ? xbox 360
  • Willow
    Willow Posts: 11,257
    everpress wrote: »
    Do you taste this often? ;)
  • Knucklehead
    LOL...you beat me to it.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • Rike255
    Rike255 Posts: 131
    I'd try a straw instead of a vacuum. Just be gentle. I heard the tape trick works well too but you have to be careful not to push it further in.
    Polk Audio RTi8 Fronts
    Polk Audio CSi A6 Center
    Polk Audio RTi A3 Surrounds
    Polk Audio PSW505 Subwoofer
    Onkyo TX-SR805
    Sony Bravia V5100 46"
    Sony Playstation 3 160GB
    Sony Playstation 3 120GB Slim
  • Kingface
    Kingface Posts: 58
    I think before you do anything.....listen to see if the sound is effected. If it isn't then don't do a thing....may not be worth the risk. I have never heard a difference in a speaker with the dustcap pushed in. Of course I say this...they were never my speakers and if someone pushed one of my dustcaps in I would agonize about it forever and do the same thing you're doing!!!!
    Onkyo TX-NR809
    Boston Acoustic VS 260 - Mains
    Boston Acoustic Vr920 - Center
    Boston Acoustic Micro 90 - Surrounds
    Boston Acoustic HPS 12HO - Sub
    Samsung LN40b650 - LCD Monitor
    Yamaha Rx-v2200
    Polk Rti 70 - Mains
    Polk Cs245i - Center
    Polk Rt/Fx - Surround
    Boston Acoustics Vr500 - Sub
    Optoma HD20 Projector
  • NJPOLKER
    I should get an old driver thats blown and dent the duct cap. Then video tape me pulling the dent with a piece of tape. Its not that difficult. If you are dumb enough to push the dent in farther or far enough you can't pull it out you should have dents in all you drivers.
  • everpress
    Willow wrote: »
    everpress wrote: »
    I know I deserve that... But this was the only time I've experienced the flavor and it was the best way I could describe it... But it worked so it was worth it.
    ? Polk PSW-350
    ? xbox 360
  • Pycroft
    NJPolker - that would be great help! Post a link here if you actually get around to doing it. I would love a sticky for those of us with kids who get them a bit damaged.
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • Polkersince85
    I feel sorry for some of you guys if you ever have a flat tire or something major to fix.
  • Rike255
    Rike255 Posts: 131
    Why? I'd have my straw with me ;)
    Onkyo TX-SR805
  • everpress
    I'd hate to know what a tire tastes like...
    ? Polk PSW-350
    ? xbox 360
  • concealer404
    concealer404 Posts: 7,440
    everpress wrote: »
    It's not pretty. Been there. Done that.
    Hankooks taste WAY worse than Kumhos, for the record.
    They also smell a lot worse when doing **** burnouts.
  • Pauly
    Pauly Posts: 4,519
    Someone suggested wine bottle vacuum years ago on here and had success.....
    Pauly
    Life without music would
  • anton.chigurh
    anton.chigurh Posts: 239
    I had a badly dented mw6502 dust cap. Tape didn't get it done so I busted out the big gun shopvac. Worked great...I can't tell it was ever pushed in.
    I might not have beaten my kid so badly had I known it was gonna work out so well. :)
  • George Grand
    George Grand Posts: 12,256
    Little hand-held vacuum cleaner does the job, almost every time.
    Toughest job was dimples in dome tweeter of one the AR-9's. It's a fabric dome, so having those dimples in there for a good length of time, was the equivalent of taking a pair of jeans that have a wrinkle in them and stuffing them in a drawer for a few years. That wrinkle is just about lasered in by then. I wasn't having much success. The dimples would come out, but immediately re-form after suction was removed. Gravity was working against me. I put the speaker face down on a couple of chairs and tried again. The dimples came out and stayed out. I left it in that position for a few more hours. When I righted it, the dome stayed a dome.
